Jaguar Kougar
I think that Kougar might still be in operation:
Home of the Kougar Classic Car Range - Kougar Sports - Kougar Monza - kouger-cars.com
In any case, the Kougar was not built on any Jaguar chassis - in the classic Brit kit car idiom, a purpose-built tube frame formed the Kougar's chassis. Then a defunct Jaguar saloon was used as the donor for the Kougar's mechanical bits - Mk 2 and S-Types (the classic one) were used as typical donors. Even a couple with a V12. In your case, since you have the in-board disk brakes, it sounds like your car is based on the 3.4 (more likely than the 3.8) S-Type. In that case, it must have the IRS rather than the Mk 2's solid axle rear end. So it is all just standard S-Type brake parts, not hard to find. Then just drop out the IRS as a unit for ease of access to all the bits.
bwilson1 (06-25-2012)
If you want to see what a ridiculously expensive specimen looks like, check this out:
1965 Kougar 3.8S Jaguar Special
Happy drooling!
Happy drooling!
