Other Jaguar Models / Concepts / Replicas Do you have a Jaguar model not listed above? This is the place to talk about it!
What is a 1988 Jaguar CXV v12? please help
Old 07-13-2007, 11:13 PM
Jose's Avatar
Received 2,445 Likes on 1,840 Posts
Default RE: What is a 1988 Jaguar CXV v12? please help
no such model.1988 is the first year in the US for the XJ-40, whether 6 or 12 cylinder. There's a Vanden Plas model (VDP), and a Sovereign model, same cars with different interior trim. You haven't found anything on it because it doesn't exist. The accessories you mention are aftermarket decorations.
Old 07-13-2007, 11:58 PM
93xj6's Avatar
Take some pictures of the car and maybe we can solve this mystery!
Basically you told us the year, but not anything about what it look, I'm assuming it's a 2 door cuz u mentioned the xjs.
Old 07-14-2007, 11:38 AM
93xj6's Avatar
You're driving an XJS then, which is a sweet ride if it's in good condition. There'sno such thing as a CXV tho, whoever did that in the title messed up. All the xjs made in 88 were V12s, and I know it'sa jaguar because they only made two types of car in the late 80s adn early 90s, XJS and XJ6. Coupe is an XJS and sedan is an XJ6.
Old 07-16-2007, 01:35 PM
93xj6's Avatar
I don't know what that is, I've never even seen it before.The front looks like a series 1 XJ6, which they stopped making after 1987, and the top looks like a trans am.
Old 07-16-2007, 02:21 PM
Jose's Avatar
that carstarted life asan XJ-6 or XJ-12, the rear doors section was chopped off,the remaining two halves joined, and the top made into a Targa-style.
Actually it looks like they did a decent job.But it is not a factory car. It is a customized XJ (sedan) body. (NOTE: the XJ-S model is a totally different body,that caris not an XJ-S).
Have you seen those limousines that are enlarged to twice the size of the real car? This is the opposite of that, it was shortened.
you can see the welding lines if you look under the carpeting behind the front seats, or under the car.
So, it is a "curiosity Jaguar" more than a "real Jaguar". The closest model to it would be the XJ Coupe, made from 1975 to 1977, in both 6 and 12 cylinder versions. But your car is even shorter than the Coupe, because it had a rear seat, and yours doesn't look like it does.
If it has a 12 cylinder engine, it must be a bullet, being so small !
But a factory car it is not. The people who did the work must have invented the "CVX"part, because no such model exists, or existed. I doubt very much that the "B" stands for "Bertone". However, why don't you write to Bertoneto find out if indeed they built it?
Also, you can send a picture to the Jaguar Daimler Heritage Trust to see if they know anything, they are the keepers of Jaguar history and they havethe complete history of Jaguar experimental prototypes.
good luck,
Jose
Old 07-16-2007, 02:27 PM
Jose's Avatar
yes,it is a Series 3 XJ body, made until 1987 (USA market) and until 1992 for the Canada market only and only in 12 cylinder version.
I can see the chrome door opening threshold plates were cut. Normally they are one piece only. I'm afraid there's no such thing as a BERONE in Jaguar history.
Must be a custom coachbuilder.
Old 07-16-2007, 03:12 PM
93xj6's Avatar
man Jose you know your jaguars. Even something that's not a jaguar, you can tell us everything about it. What are you a super computer. I thought he just photoshoped stuff and was screwing with us, but you can find like all the welding poitns and everything.
Quality post Jose, you da man
Old 07-16-2007, 04:19 PM
Jose's Avatar
thanks. I love Jags, better than any other car. There's somethin' about 'em that fits my style. But I like the old Jags better, they were simple cars with a lot of power and handling quality.
Old 07-16-2007, 04:23 PM
93xj6's Avatar
Jose you gotta put some pictures up of your car...I forget what you said you owned.
Old 07-16-2007, 07:32 PM
Jose's Avatar
here ya go....
[IMG]local://upfiles/1235/4E6443E181684023A93F4512ECD86588.jpg[/IMG]
Old 07-17-2007, 11:41 PM
93xj6's Avatar
Those are some mean front ends Jose, they don't make em like that anymore.
Old 07-18-2007, 06:39 AM
Jose's Avatar
here isa bit of detective work: if the car is a 1988 and a Series 3 XJ, then we know it has to be a 12 cylinder, (and we know it is), and that means the car was most likely from Canada, because the last year for the Series 3 XJ cars exported tothe USA was 1987, but Jaguar kept exporting the Series 3 XJ in 12 cylinder version to Canada until 1992.
So chances are the BERONE company is in Canada. And yes, the sill plates are stainless steel, not chrome. My point is that they are cut in two pieces, when normally they are one piece.
Old 08-15-2007, 10:01 AM
My god!!! It lives! What you got there my friend is a stock 88 XJ some idiot has chopped in half and rejoined. If you bought it for colector value, I'd estimate present value of around $0.00 although if you bought it because you like it then it's likely an ok buy for you. I'd be very concerned about the joints, as many of the older stretched limousines came apart at higher speeds with predicable results. As someone said with the V-12 this car will be light, overpowered,and I'd guess a tad skittish. Who knows what stresses this modification will place on the car? I highly doubt the alterations to frame and body were engineered by Jaguar, so be very carefull my friend... very carefull.
Quick Reply: What is a 1988 Jaguar CXV v12? please help
