Other Jaguar Models / Concepts / Replicas Do you have a Jaguar model not listed above? This is the place to talk about it!
XJ-PU-V12 first fire up after re-build
Old 02-26-2015, 04:58 PM
moff1959's Avatar
Default XJ-PU-V12 first fire up after re-build
The blue lit switch is the electric choke with push button start,
Flint Ironstag (04-22-2015)
Old 04-22-2015, 02:38 PM
Flint Ironstag's Avatar
Ha ha - love the startup! Would be interesting to see just how much easier this is to maintain vs. an XJS. So much more room to work with and access components!
Old 04-22-2015, 06:25 PM
moff1959's Avatar
I made my own fuel injection harness, cleared out all the vacuum stuff apart from the essentials distributor, brake servo, ECU and trans modulator, custom ignition system, custom fuel pressure regulator and fuel system so far the engine has not missed a beat, I did want to prove that Jaguars can be reliable and so far its only the TM400 I have a problem with.
Old 06-06-2015, 07:35 AM
moff1959's Avatar
Swapped out the transmission a few weeks back and now I have a running truck again, put 50 miles on it just tooling around still trying to get a feel for the handling slowly increasing my speeds and acceleration so far so good, have a modified TPS I want to fit and a few other mods.
hoodun
09-28-2015 01:08 AM
Bowman
09-03-2015 03:17 PM
Quick Reply: XJ-PU-V12 first fire up after re-build
