DIY S-Type 4.0 Remove and Replace ~ Coolant Reservoir Tank FAQ
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
Hey team,
It’s just me Tdc again with another one of my How I did it threads, just incase anyone wants to know.
I was leaking coolant from the engine compartment, rear – on the driver side and determined it to be my coolant over flow tank. I ordered one up a new one and well here’s how it went, via pic’s..
Removed the windshield wipers, then I remove the plastic covers, then remove the hex screws.
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8621-1.jpg)
Now, I removed the cross bar
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8623.jpg)
Now with everything out of the way, I was free to remove the (3) hoses and the unit itself.
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8625-1.jpg)
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8626-1.jpg)
Here are all of the parts that were removed for this project
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8629-1.jpg)
Here we have the side by side view
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8627-1.jpg)
Ok the new one is going back in, the only problem here is fitting the bottom hose under and connecting it up.. small hands are deffetnly required, as I had my son (14) actually perform the final hookup.. With dad’s observation and approval of course.. hahahaa..
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8631.jpg)
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8633-1.jpg)
Here we go team, everything is back together and we have no leaks..
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8635.jpg)
The total cost for this project was $86.00 for the reservoir tank.
The total length of time spent on this project was 90 minutes
Thank you all for your time and have a great one everybody..
Tdc..
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8632.jpg)
Tdc..
The following 6 users liked this post by tdc:
a100steaksauce (11-25-2010),
Cadillac (11-26-2010),
joycesjag (11-26-2010),
mizdereon (04-02-2014),
scampy (04-21-2013),
and 1 others liked this post.
Received 9,010 Likes
scampy (04-21-2013)
Hey tdc, thats a nice write up on the coolant reservoir change, thanks for sharing.
It'll be a nice add on to the FAQ section. One of the mods will no doubt sort this shortly.[/quote]
Thank you Jim.. I know I’m just the new guy here, but I’ve got a lot of work to do on my car and as long you guys allow me I’ll keep posting them up..
Thank you again for the honor of allowing this so-Cal, single dad a place to come and be with… well other adults.. LOL..
Hey best of luck to you Sir.. It wasn’t really a hard job at all.. The only problem I had was connecting the bottom hose, big hands..
Wishing you the best..
Cool.. I'm happy to hear it's worthy.
Thank you for the honor..
Hahahaa.. That’s soooo funny you mentioned your light... LOL.. I'm just now (right now) trying to think how and the poop I'm going to change my passenger side front light.. I bought the bulb and removed the rear cover from the headlight assembly, but I think I’m SOL... ie I might have to remove the hole front clip??? IDK --- TBD..
If you’ve got some advise I’m listening.. and thanking you ahead of time..
Thank you sir.. I'm glad you and others liked it.. ever since I bit the bullet on the timing project, I'm going to try to be my own mechanic for a while and see how it works out.. Hahahaa. Wish me luck with that one.. lol..![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
Thanks TDC, I just did mine, here are some pictures of the faulty one, look how many cracks it does have, and mine was leaking from between the plastic unions.
My wipers were the most time consuming parts to remove due to old dirt, even with W40, finally the trick was to use standard "locking plyers", one side on top of the screw and the other on the bottom of the wiper and just push a little to create a locking pressure.
![Name: oct2010001.jpg
Size: 46.1 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/175417d1501294008-diy-s-type-4-0-remove-replace-%7E-coolant-reservoir-tank-faq-oct2010001.jpg)
![Name: oct2010004.jpg
Size: 38.6 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/175418d1501294008-diy-s-type-4-0-remove-replace-%7E-coolant-reservoir-tank-faq-oct2010004.jpg)
Received 2,637 Likes
In my reply to your thread, I mentioned how to remove the lower hose from the heater pipe. Use a tool for removing the constant tension clamp and move it up the hose, then use a hose tool or pliers to loosen the hose and remove it along with the tank.
Replace the tank as it's most likely cracked like the ones shown in this thread.
stanjag
08-30-2015 10:35 AM
innzane
08-27-2015 07:58 PM
