00 S Type Front Outer Bar Link Replacement
Hi, so I had the inner tie rods and tie rod ends installed on my 00 S Type with new boots (both sides for safe measure) - I wound up going under the car to check the work performed (good habit I say) and I found the sway bar link (driver's side) - rubber boots cracked and broken - the sway bar link is intact - I'm going to replace both sway bar links but the question I pose is as follows:
Should I get the allignment done before I get the replacement sway bar links installed or should I wait?
Would installing those sway bar links throw off the allignment?
Any advice would be appreciated. Thanks
Doberman_Fan
22
12-24-2019 06:21 AM
Paradigm
06-15-2019 05:59 AM
stanjag
08-30-2015 10:35 AM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
