ABS fault after installing rotors and pads
Old 02-15-2011, 05:16 PM
08Z06's Avatar
Default ABS fault after installing rotors and pads
Hello all, any ideas on what to check? I spent the afternoon putting slotted rotors on the front of my car. I previously only had the rears done. After i drove it to set the brakes in, the ABS fault light came on. It took a few miles to light up and won't go away now. Any insight would be appreciated. Everything looks good
Old 02-15-2011, 05:55 PM
vance580's Avatar
I would check the ABS sensor wires. They are clipped to the brake line so when you removed the caliper they may of came off and possible could of unplugged somewhere. Thats the first place I would check.
Old 02-18-2011, 09:52 AM
androulakis's Avatar
Do you have a scan tool? Can you scan it and tell us the codes?
Where in NJ are you exactly?
Take care,
George
Old 02-18-2011, 10:16 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
Chances are an ABS/DSC fault code will only be stored in that module.
It's on the CAN bus and may also be on the ISO on the MY of his car.
An ordinary (generic) OBD tool won't know where to look for the module.
No harm scanning, though.
If you've an elm327 and want to try it let me know (it's safe).
Old 02-18-2011, 10:19 AM
He's reasonably local, and I have a handheld ABS scan tool
ABS codes on an S-Type will come up as Cxxxx Codes.
Take care,
George
Old 02-18-2011, 10:39 AM
JagV8's Avatar
In that case his best option is probably to take you up on a generous offer!
Old 02-27-2011, 05:19 PM
jonnystypercooper's Avatar
I know it's a year since the original post but LISTEN UP!
I just had the ABS fault light come on in my 2005 S TYPE R. This was 10 minutes after going through a car wash and weeks of driving through snow in the harsh Michigan winter, i even got stuck once which led to the unable to apply parking brake fault(this was rectified by a 10 mile drive to get the snow from the calipers and then turning off then back on)
Anyway ABS! I tried turning on and off without success this did however cancel the DSC error message i recieved initially with the ABS fault. I then Tried a Battery disconection...NO LUCK. So i thought i would try and go for a spin to see if it was caused by water from the carwash in the sensors, maybe i could dry it off on the freeway. Anyway as i drove down my driveway in the snow i thought i would test the ABS to see if it actually was failing. IMAGINE my surprise when it worked and the fault light went off! No jag dealer or repair needed.
It would seem that the control unit need to know that it worked in order to tell itself there wasn't a fault and it worked fine.
In short, if you recieve this message and cant reset it, Stress test the ABS and get it to grind, it might work for you as well.
Gunmucker (02-01-2013)
Old 02-27-2011, 05:21 PM
I apologise! this is a fresh post and not a year old. but i cut and paste from a post i made on another forum. sorry. But the facts a pertinant!
H20boy
07-23-2021 09:39 PM
PMKimpton
08-03-2019 08:22 PM
ym37tech
02-08-2016 01:04 PM
handcuffsready
09-07-2015 01:02 PM
JagLove86
09-06-2015 10:36 PM
Quick Reply: ABS fault after installing rotors and pads
