AC blowing warm and high pressure on low side
I have a 2005 S type that the AC is blowing warm air and when I hooked up a gauge to recharge it the pressure on the low side was about 90. It gets a liitle cooler when the car is moving but warms up when the car stops. Anyone know where to start looking for the problem.
Welcome to the forum!
You should really follow forum protocal and introduce yourself in the "New Member" section. By doing so you will access to much, much more information.
Also go to "UserCP" upper left hand corner and "Edit Signature", please add your vehicles details, like so many of us have. Thank you!
Have a look at this TSB BEFORE you spend alot of money!
JTB00183NAS1.pdf
Now if you are giong to replace the compressor here is another link with what you will be looking at!
https://www.jaguarforums.com/forum/s...ics-faq-55212/
![](https://www.jaguarforums.com/forum/images/kirsch/attach/pdf.gif)
Thanks Rick I just updated my signature and posted in the new member section. I did take it too a garage and the guy told me it was 1lb low and that the expanison valve was cloged and I need to run it to clear the clog. That does not sound right to me. I'm going to go pick up some gauges so I can check both pressures. How would I know if its the compressor spring valve or somthing else.
I would first check out the TSB joycesjag included in his response regarding your original post. I would attempt that first before investing $$$ in a new compressor. It's worth a try and swapping out the compressor spring has worked successfully for other forum members. Good Luck and keep us posted.
Received 2,192 Likes
The system only takes 1.6 pounds, expansion valve clogged???whatever, the only thing that would plug the x valve is drier desicant bag coming apart and dumping pellets in the system youll never clear that or any other clog. The high side should read 150% of ambient temp in front of condensor as a general rule of thumb. I prefer to evacuate system to see whats in it and charge with correct weight of freon.
This worked on your V8? I have a V8 with the same problem, someone on this forum told me the TSB doesnt apply to my V8.
Listen, my understanding of this forum is to help one another, not try to get the last word. If you read my post, I was addressing someone else other than you. I asked them, if they used this procedure on a V8, why dont we start with you telling me what the difference is between the two compressors? I am a very logical person, I couldn't see a V6 having a completely different compressor for the A/C than the V8, unless you have a logical explanation. I don't know how old you are but the bickering has to stop. This is a public forum, newbee or not.
