Acronyms, mainly car/Jaguar (How To)
Probably time for an updated list:
Code:
4WD four wheel drive A/C air conditioning AAI air assist injection (a valve, fitted to the 4.0 V8) ABS anti-lock braking system ACCM A/C control module ACM audio connectivity module ACT air charge temperature (see IAT; an OBD critical sensor) ADHLS Axle Deflection Height Levelling System (for self-levelling HIDs) AE AutoEnginuity, an advanced OBD tool AF or AFR air/fuel ratio APP accelerator pedal position (critical sensor(s)) ARTS adaptive restraint technology system AWD all wheel drive BARO barometric pressure (an important OBD reading) BT Bluetooth bus a way of connecting multiple computers so they can talk to each other CAN controller area network (often, higher speed OBD protocol mandated by EU & USA) CAT catalytic convertor CATS (plural of CAT or) computer active technology suspension CC cruise or climate control CCM climate control module CEL check engine light CHT cylinder head temperature (not a generic OBD sensor) CKP crankshaft sensor (a critical sensor) CL closed loop (engine being controlled by feedback from O2 sensors) CM control module (often, having a computer inside) CMP camshaft sensor (a critical sensor) COP coil on plug (where each spark plug has its own coil) CTS coolant temperature sensor (see ECT; an OBD critical sensor) cyl cylinder D2B an optical fibre communications path DCCV dual coolant control valve (aka DCFV aka water valve aka heater valve) DCFV dual coolant flow valve (aka DCFV aka water valve aka heater valve) DFCV dual-flow coolant valve (aka DCCV etc) DD daily driver dead locking see double locking DIY do it yourself DLC data link connector (proper name for the OBD connector) double locking locking doors and the internal door levers (aka dead locking) DPF diesel particulate filter drive cycle very complicated driving so PCM exactly relearns car characteristics DSC dynamic stability control DTC diagnostic trouble code (the way OBD reports problems) EBA emergency brake assist ECT engine coolant temperature (an OBD critical sensor) ECU (non-unique) electronic or engine control unit (such as PCM or TCM) EGR exhaust gas recirculation ELM an OBD device made by Elm Electronics ELM327 complex ELM, supporting all common OBD protocols EML engine management light (see MIL) EMS engine management system EOBD European OBD EOT engine oil temperature (not a generic OBD sensor) EPB electronic (or electric or emergency) park (or parking) brake ETM engineering test mode EVAP evaporative purge (about control of fuel vapour) facelift/redesign (tweaks) 2005/6MY or (major changes) 2002/3MY FAQ frequently asked question FEM front electronic module (aka GEM aka GECM) fob the (electronics of the) part attached to the vehicle key FWD front wheel drive GECM general electronic control module (aka GEM aka FEM) GEM general electronic module global opening/closing opening/closing all doors, windows, sunroof/moonroof GTR global technical resource (link from Jaguar home page), now TOPIx HEGO heated exhaust gas oxygen (usually about a type of sensor) HID high intensity discharge (a type of light) HO2S heated oxygen sensor (a critical sensor) HP horse power (a measure of power, such as engine output) HS high speed (often about a type of CAN) IAT intake air temperature (an OBD critical sensor) IAT2 second IAT (sensor) (commonly, after turbo or SC; a critical sensor) ICM instrument cluster (or control) module IDS integrated diagnostic system (a dealer tool; very expensive) IMT intake manifold tuning (a valve/transducer to change the intake size/shape/flow) IP injection (fuel) pressure sensor or instrument pack IPK instrument pack (aka instrument cluster or dash) IR infrared ISO the International Standards Organisation (ISO 9141 is a type of OBD) JTB Jaguar Technical Bulletin (see TSB) JTIS Jaguar technical information system (computer-based workshop manual) KAM keep alive memory (volatile memory where the PCM stores learned values) key vehicle key or computer passcode KS knock sensor KWP keyword protocol (a form of OBD) LH left hand (car directions are relative to driver when facing forward) LHD left hand drive LPG liquified petroleum gas LSD limited slip differential LTFT long term fuel trim (aka LONGFT), extra fuel being added/subtracted MAF mass air flow (a critical OBD sensor) MAP manifold absolute pressure (a critical OBD sensor) MIL malfunction indicator lamp (sometimes called CEL, EML or SES) MPG miles per gallon (N.B. USA gallon is 80% of UK gallon) MY model year NA naturally (or normally) aspirated (so, not turbo and not SC) NAS Jaguar's term for North American Specification NCM navigation control module O2 oxygen OBD on board diagnostics (nowadays short for OBD-II or OBD2) OE original equipment (as fitted/supplied by the manufacturer) OEM original equipment manufacturer oil gimme a break OL open loop (engine not being controlled by O2 sensors) PAS power assisted steering PATS passive anti-theft system PCM powertrain control module (commonly engine controller but may do more) PCV positive crankcase ventilation PID parameter ID (a name or number identifying a measured OBD parameter) PM particulate matter or private mail PSE phone support equipment PWM pulse width modulation (a way of controlling electrical output) RCCM remote climate control module RCM restraints control module RECM rear electronic control module (aka REM) REM rear electronic module (aka RECM) rev reverse or revolution (aka RPM) RH right hand (car directions are relative to driver when facing forward) RHD right hand drive RP restricted performance (aka limp home mode) RPM revolutions per minute RWD rear wheel drive RWHP rear wheel HP Sat Nav satellite navigation SC supercharger (or supercharged) SCLM steering column lock module SCP standard corporate protocol (a Ford form of OBD) SDD symptom-driven diagnostics (an expensive dealer tool) SES service engine soon (see CEL / MIL) SRS supplementary restraint system STFT short term fuel trim (aka SHRTFT), see LTFT STR S-Type R (the supercharged S-Type) TB throttle body (a critical, high-precision air-flow control device) TC torque convertor or traction control TCC torque convertor clutch TCM transmission control module TCS traction control system TOPIx Jaguar's new name for GTR, now at topix.jaguar.jlrext.com TPS throttle position sensor (critical OBD sensor(s)) TQ torque tranny transmission TRQ torque TS twin screw (supercharger) TSB technical service bulletin (a fix for/details of problems) UHEGO (badly named) so-called "universal" (they aren't) HEGO UV ultraviolet V6 6-cylinder engine arranged as a V of 2 groups of 3 V8 8-cylinder engine arranged as a V of 2 groups of 4 VCT variable cam timing VIS variable intake system (see IMT) VPW variable pulse width (a GM OBD protocol) VSS vehicle speed sensor VVT variable valve timing WB wide band (e.g. a type of O2 sensor) WDS world diagnostic system (an expensive dealer tool now quite old) WHP wheel HP WOT wide open throttle (aka kickdown) WSS wheel speed sensor ZF a German company (maker of gearboxes, steering racks and much more)
The following 67 users liked this post by JagV8:
Arthur Dent (09-16-2012),
bassman64 (04-19-2014),
Blueneck (01-25-2014),
Bob OB (10-06-2013),
Carlg07 (12-16-2015),
and 62 others liked this post.
The following 3 users liked this post by Bad Cattitude:
Received 6,306 Likes
The following 2 users liked this post by Norri:
gr1 (11-08-2015),
Stuart Beattie (09-11-2013)
Hi Comrade Gibby,
If you click on User CP at the top left of the page, you will see that boxes drop down, you can then click on Signature and add the details you want.
After that you will see your efforts depicted in your posts and having seen other users profiles you can adapt it to your style. Also if you go further down the page as you are editing the signature you can add images and icons.
I hope that helps, Good luck and Nice Car! Stu
Glass-man
12-26-2016 06:46 AM
5tevie
10-15-2011 04:51 AM
automotive, back, bulletins, car, directions, information, iso, jaguar, powered, store, system, technical, temperature, topix, unit, vbulletin, water
