Car wash/Limp mode
Hello All!!...
Took Jaggy over to the car wash today (I've had it there before). It's the kind where you sit in one place and the machine moves. Actually...it does a very good job, even the wheels (the only part with a brush). Anyhoo...as I went to pull out, I noticed the engine was ideling high. I pulled over to the vacuums and I had a check engine light, DSC fault, Hand brake fault and system engine fault.
So I shut her off and restarted... same thing. I limped her home (at 10 mph) and shut her off again. Turned her on (started it up) and same faults were reading again. I disconnected the positive terminal of the battery for 30 or so seconds and tried again and presto...all faults were gone except it now said apply foot and hand brake. After doing that, I still had the engine light (orange) so I ran up to the Ford store where they generaly read my codes for me, ( the car was no longer in limp mode) but the service guy who does that was at lunch. So...I went to two other places where they said they didn't have a reader. When I left there I started the car and the engine light must have reset itself, because it was off. Now it's running fine. Had to reset the windows also. Sure wish I knew what triggered the faults. I guess I'll have to hand wash her from now on.. Oh well...it could have been worse...
Drive On!!...![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
Fast Freddie
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Drive On!!...
Fast Freddie
![Icon Patriot](https://www.jaguarforums.com/forum/images/smilies/icon_patriot.gif)
The same thing happened to me several times after going thru the car wash. Would shut it down, wait several minutes and then it would start back up just fine. Told my dealer about it and he fabricated some kind of cover for some kind of sensor.
The problem cleared right up.
Sorry about being vague. The next time that I go to the dealer, I'll ask him to tell me which sensor he covered up.
I also have an 05 str.
If you use Search or even better Advanced Search and choose just this forum, you'll find this is fairly common and almost always due to water going where it never should. Sometimes due to a leak which has developed and needs sealing (such as below windshield - we say windscreen). Other times a connector which again should be sealed but over the years now isn't (such as at throttle body). Have a good read as the fixes are there too.
Thanks Fellas for the reply
FireCat: I would appreciate the name and location of that sensor should you get a chance, then mebbe I can keep this from happening again.
jagv8: I know what you mean. I've looked under that long plastic piece at the bottom of the windshield, you immediately see the bottom of the glass. And the cover doesn't even seal the window and water can get in there easy enough. I don't know what is below there... obviously some kind of drain for water that gets in there. And I agree, search and advance search works just dandy...IF... you know the correct words to search for. Otherwise it doesn't show you anything. In this case, what would you use..."windshield seal"?, "car wash"? "wet engine"?....
Thanks again fellas
Drive on!!...![Icon Bike](https://www.jaguarforums.com/forum/images/smilies/icon_bike.gif)
Fast Freddie
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Thanks again fellas
Drive on!!...
Fast Freddie
sigh these cars man, I use a rinse-less car wash now
I remember on one of the posts some people having the same problem with the water which I had also experienced. It was suggested I take a clear silicone and apply between the windshield and rubber that the windshield sits in at the bottom of the glass to better seal it. You can peel back very carefully that piece of rubber to apply the silicone. Not sure how the water was working its way down from there but did what was suggested and have not had an issue since. Took a couple of minutes.
Hello All!!...
Fast Freddie![Icon Patriot](https://www.jaguarforums.com/forum/images/smilies/icon_patriot.gif)
Drive On!!...
Fast Freddie
Isoruku
06-19-2020 12:54 PM
Ziggybeben
08-30-2015 02:09 PM
