Help!! Code P1108
OK, first of all where are you getting your code read from? It is WRONG.
I know people keep stressing that you need to read the FAQ's....This is a perfect example.
From the Jaguar DTC pdf that is found in the FAQ section.....
P1108 is a MAP sensor high volt code....
Please download this PDF and keep it handy...And go through and read up on all the other very usefull things in the FAQ section...
STR (12-14-2010)
All P1 codes are maker specific. The maker can use them to be specific to model, engine, year or anything else. (Which is either flexible or confusing or both!) The code PDF was posted here not very long ago, I think by oldengineer (try his posts). File P2003MY_X202.pdf
Always look up a P1 code for your specific car details (any make - same rule).
There's also some troubleshooting info if you Search on here.
P1108 for your car is "MAP sensor sense circuit high voltage" and the PDF I mentioned has lots more data
STR (12-14-2010)
P1108 does NOT mean that.
P1108 for your car is "MAP sensor sense circuit high voltage" and the PDF I mentioned has lots more data![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
That's exactly what I said.....
STR (12-14-2010)
STR (12-14-2010)
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
I've tried clearing the code and it stays off while I'm driving but when I turn the car off and leave it for 10 second and restart the car it come back.. I checked the fuses and they are
all good.. I will try taking a look at the map sensor and the coonections..
Thank you for your help and everyones else too .. I really appriciate it....
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
It's all good.....
I'm stoked that I had the same answer as the "Guru".... LOL
I figured you would have posted sooner... Got scared you fell into a snow drift....
STR (12-14-2010)
Hi JOsworth I'm using a OBD 2 scan tool
I would pick up a MAP sensor. My dealer lists them for $156. You may be able to find a less expensive source. I would then check the wiring connectors and the MAP sensor itself and see if it can't be "cleaned" or "serviced"... If not, then just install the one you picked up.
This is simply the "process" I use any time I have a sensor failure. I try to service it first but only after I have a replacement. Oh, and make sure that whomever you purchase the sensor from will allow you to return it if it ends up you don't need it.
STR (12-14-2010)
I want to thank everyone that help me with my check engine like..
It was the MAP sensor and now I have no more check engine like.
The Map Sensor was a like time comsuming but not hard.
It was located behind the lower throttle body and you have to remove both of them to get to it, well I had to remove several things to get to the map sensor but its working now.... THANKS!!!...
STR (12-14-2010)
philwarner
25
06-26-2021 05:43 AM
