Help?How do I change the fog light bulb on an S-type ?
2000 model
similar to an x5 bmw
take the air sperator off first if you have one 3 Small clips turn them 90 degrees and take off now remove the 2 Black plastic covers next to the fog lights there along side of them
3) unscrew 2 screws from ech light housing and pull it out
from behind twist to the left and you will see the H3 bulb undue the clip or squeeze and you are good to go
not as hard as it sounds
take care
take care
Oct214 (07-09-2021)
This question has been answered for your model by kparsells.
When I did this job. The outer plastic part (wiring side of connector) was seized together and fell apart in my hand. So it may be brittle.
take care
take care
Gatorman67 (10-09-2022)
