HELP ! my gear is stuck at P
Hello every one im new here i would like to discus my problem in order to look for a solution and help others who could face a same one.
I have s-type jag 2003 v6, the engine starts normally but a yellow light with a restricted performance message is displayed, when i press the brake pedal to shift the gear it doesn't shift and the clicking sound is not heard i tried million times and nothing is going well
I checked all the fuses and all work good!
So what the problem could be ??
No i didn't
Im also thinking that this might be the problem, but can you tell me exactly where i can find those bolts and if u have a picture of it or the place where it is located.
thanks in advance
thanks in advance
I'll do one better watch this and skip to about 1:10 of this video and it will show you the bolts.
oilchange2 - YouTube
The following 3 users liked this post by vance580:
Also something to remember. DON'T GET ROUGH WITH THE SHIFTER!!!! You will break it and has been posted it's very expensive. It's tempting to keep pulling on the shift lever but it's plastic and you will over power it.
You have been given the two most likely things. The bolts under the car on the tranny and the solenoids inside the car in the console.
Now here is an easy one and always check it first. Do you have brake lights? If not then you can't shift out of park because the car thinks you don't have your foot on the brake pedal while shifting out of park.
Received 2,192 Likes
take a striaght razor blade to the plastic pin the locks the shifter cam and voila, no more shifter lock
