HELP! PATS Sytem!
HELP! PATS Sytem!
First, I am new to the site so hello everyone!
I just bought a 2002 S-type with the 3.0 v6. I just fixed a draw issue with the car. If it sat for a few days the battery would be weak and I couldn't start the car.. It was a bad battery so I since replaced it. Anyways, I narrowed the draw down to the ignition switch. Something must have failed inside and the radio was not turning off completely when I would leave the car. I replaced the ignition switch and battery and now the car will not start. I have tried both keys in the switch but the PATS light just blinks rapidly. I read about getting the DTC for the PATS system and I ended up with a code 61. I have tried disconnecting the battery for an evening hoping the ECU would reset and accept my keys. Another wierd thing is that the OBD port doesnt respond either? No code reader can communicate with the vehicle. What have I done?! I really want my car back on the road!
Does anyone know how to reset the PATS system or ECU? I tried putting the old switch back in but that didn't do anything.. I really don't want to take it to Jaguar. The closest one to me is about 70 miles and I would have to get a tow..
im very familiar with the PATS system........ if you mounted the ring at the front of the cylinder correctly, you MUST HAVE THE DEALER reprogram the codes for the new key. I imagine since you did the ignition switch you have new keys. And they do not match the door correct?
if you had no need to change the keys, and you didnt mess with the antenna ring, then either the ECU is in a long term tamper mode, or something is disconnected somewhere. If you tried to start the vehicle too many times without the transponder being "seen" by the antenna, it will cause the no start condition.
UKnFor-dluv-expat
09-26-2015 09:40 PM
stefon
11-22-2007 02:52 PM
