New member Intro and my build thread (air ride, check it out!)
Well first off Hello to everyone! I just picked up my S about a few months ago for 4500 with 100k, I wouldn't say it was steal but it well worth the money! This is my first jaguar as I've been a Euro junkie since I was 16. From BMW, to VW to Audi and back. Now Jaguar and to be honest as much as the transmission problems scare me with these cars I love it.
Now on to the fun stuff, my air ride build
I kinda took a quick look through the threads before I started this and didn't find much on anybody doing air ride in there S type so I figured I'd snap some pics along the way and show everyone what worked and what didn't.
I started off with a universal kit from "bagriders" in VT great people btw and very helpful. Aerosport 2 bags which are A "bag over coil" setup (for thoes of you who don't know they basically slip on to your strut and take the place of your spring.
Started off with this. I bought the 20inch Arden wheels same day and was too anxious to wait so I have no photos of it completely stock.
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zpscfe0b415.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zpscfe0b415.jpg" border="0" alt=" photo image_zpscfe0b415.jpg"/></a>
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zpsefe704a8.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zpsefe704a8.jpg" border="0" alt=" photo image_zpsefe704a8.jpg"/></a>
Aerosport bags used.
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zps153b77df.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zps153b77df.jpg" border="0" alt=" photo image_zps153b77df.jpg"/></a>
Strut disassemble an bag placement, normally the bag has a bracket that you weld to the perch or if your brave enough you weld the bracket to the shock. (After your completely strip it apart of course ) DO NOT WELD TO GAS FILLED SHOCKS. Trust me.
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zps2b85fe68.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zps2b85fe68.jpg" border="0" alt=" photo image_zps2b85fe68.jpg"/></a>
Spring perches were than trimmed and aerosport Bag bracket was welded to spring perch and everything repainted nice glossy black. Here comes the fun part, the stock front shocks were a tiny bit too large so off to the junkyard we went in search of the same style shock assembly but shorter and more piston travel, when we came across a BMW e39 with the rear shocks still in it, we pulled one out and played around with it a while, after some overnight research I found they were not only 2 inches shorter but had a stronger valving inside the shock which allows me to go up and down more often without going through shocks every month.
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zps48ebbd7c.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zps48ebbd7c.jpg" border="0" alt=" photo image_zps48ebbd7c.jpg"/></a>
The rear shocks worked just fine, the only modification I did was since the spring Perch was only held in by a snap ring I cut another slot for the snap ring to sit on the shock with a dremel tool and moved the perch 2 inches lower on the shock. Sorry no photos this is when I found welding to a gas shock may not have been my most intelligent moment of the build.
That was it for the struts after brackets were welded in place to the trimmed spring perch the bags bolted up to the brackets and the original top hats were used and everything was put back in the car.
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zpsae82f3a0.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zpsae82f3a0.jpg" border="0" alt=" photo image_zpsae82f3a0.jpg"/></a>
On to the interrior, Trunk set up and deciding where to put 2 dual needed gauges and make it look original and clean.
Cup holders under the armrest!
I bought a sheet of plastic and trimmed it to fit on the inside of the cup holder than did a little custom plastic welding with a few zip ties and than wrapped in in some black suede
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zps069b8681.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zps069b8681.jpg" border="0" alt=" photo image_zps069b8681.jpg"/></a>
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zps79a1369f.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zps79a1369f.jpg" border="0" alt=" photo image_zps79a1369f.jpg"/></a>
Trunk setup, bulkheads, airline and tank and compressor setup. And mounted.
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zps77fa3a89.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zps77fa3a89.jpg" border="0" alt=" photo image_zps77fa3a89.jpg"/></a>
Spare tire removed and everything hidden but the tank.
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zpsc9ac0404.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zpsc9ac0404.jpg" border="0" alt=" photo image_zpsc9ac0404.jpg"/></a>
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zpsf4cecced.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zpsf4cecced.jpg" border="0" alt=" photo image_zpsf4cecced.jpg"/></a>
Everything's just about done. Gauges mounted, strut towers cut and trimmed in the wheel well so no sharp objects come anywhere near the rubber bag that took place of my spring. Air line run everything powered up an grounded out.
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zps1aec99cd.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zps1aec99cd.jpg" border="0" alt=" photo image_zps1aec99cd.jpg"/></a>
She's out!
<a href="http://s1330.photobucket.com/user/00Stype/media/image_zps64843a98.jpg.html" target="_blank"><img src="http://i1330.photobucket.com/albums/w573/00Stype/image_zps64843a98.jpg" border="0" alt=" photo image_zps64843a98.jpg"/></a>
She's out!
thebiglad (08-02-2013)
I apologize if the pictures did not work, I am a novice! So here is the link p my photobucket just incase! Enjoy!
http://s1330.photobucket.com/user/00...?sort=3&page=1
It's not my scene, but an excellent "How to".
I find it interesting the idea of air suspension as it usually gives excellent comfortable ride qualities. No so interested in "slamming" my car like yours as I don't think it would survive on our rough country lanes.
Can you give some feedback on how the car drives, with this set-up please?
Received 9,007 Likes
Thanks everyone! I have to be honest the ride quality depends on how low or high I drive the car. The pictures I posted are of the car fully aired out. And with the wheels tucking like that there's no chance I'd be able to drive it like that. When I air up its about an inch or two lower than stock ride height. Which is perfect! The bags hold a max psi of 110 and my daily driving height is around 80psi so the bag is ony partially inflated which allows more cushion. The higher the psi the stiffer the ride quality and even with the bags maxed out it rides like I'm on Coilovers. Anywhere between 40-90 psi it rides just like stock if not more comfortable. I have to say I love it. And I love the attention it catches! But recently I have been finding when I'm aired out all the way and I lock my car any little gust of wind will set my alarm off.. Has anybody ever had any randomly sounding alarms in the s type? Or am I just over reacting?
I actually picked them up from a guy locally not knowing what they were for 300 bucks! Than brought them home and did a little research and almost died hahah what a great find.
And ill double check the battery, I hope it's not dieing it's brand new!
Originally Posted by totalimmortal363 View Post
At least you're only ruining a pre-2003 S-Type....
I agree, very harsh, great engineering even if it doesn't appeal to all.
Most of us are just mere mortals after all.
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
rudelover2
09-11-2015 08:53 PM
