OBD Scan Software
OBD Scan Software
Just waiting for a usb scanner to arrive (elm 327) and have been
offered the software listed below, but i don't have a clue about any of them, i've never used a an obd tool, so am looking for something simple to use to read codes with to start.
Can any of the software listed change/program anything on my car with an elm 327 ? (i don't want to wreck my car)
So, any recomendations ?
* AutoEnginuty ScanTool v.6.0.2
* Carsoft BMW v.6.5
* Carsoft Mercedes Benz v.7.4
* DDT2000 Renault v.2.0.9.0
* Diagnose v.4.1
* DigiMoto v.4.03
* EFI LIVE v.4.6.5, v.7.5.4, & v.7.5.5
* ECM2001 v.3.2
* Finalist v.1.0
* FordScan v.2.02
* Galleto OBD2
* INNOVA 1003c Program
* INPA v.5.0
* KWP2000
* OBD Diagnostincs, Inc. CD
* OBD Wiz
* OBDTool v.1.2.60
* OP-Tech2
* PCMscan v.2.4.5.824
* ProScan v.5.6 & v.5.7
* ScanMaster ELM v.1.6 & v.2.0.7
* TachSoft Mileage Calculator v.1.2
* Carsoft BMW v.6.5
* Diagnose v.4.1
* DigiMoto v.4.03
* ECM2001 v.3.2
* Finalist v.1.0
* FordScan v.2.02
* Galleto OBD2
* INPA v.5.0
* KWP2000
* OBD Wiz
* OBDTool v.1.2.60
* OP-Tech2
Some (e.g. AE - AutoEnginuity) won't work with an elm.
Some sound the wrong car make.
elm will likely come with some free software or else download it.
Your car's PCM does not use KWP.
mileage calculators are IMO pointless.
There's a site sticky somewhere (Gen Tech?) about OBD tools that's worth a hunt through. AE is in there, with others.
Received 6,361 Likes
What platform are you going to use?
I bought one of the cheapo $25 elm327 USB adapters about 6 months ago.
My current platform options are an Ipad or a windows mobile 6.5 phone.
There's very little out there for either of those in combination with the elm usb.
I haven't been able to get anything to work reliably so I haven't bothered to buy any software.
I am a bit suspicious at this point that the elm isn't completely working properly though it does pair up with my windows phone and the Ipad (jail broken) but then the tough part starts.
Dashcommand looks sort of OK for the Ipad but they're free trial version just won't stay linked up with the IPad using the ELM327 USB even with the jailbroken new BT stack installed. There could be multiple problems involved.
After looking over the various forums I get the feeling WIFI is better anyway. Even when I could get the BT working for a stretch it was terribly laggy and most the software is really into a bunch of useless display graphics that also operate terribly if the data stream isn't fast or your processor isn't powerful. Maybe it's much better on good laptop?
Frankly, I just like cables better anyway. Much simpler.
I've just about decided to give up on the BT elm.
* Carsoft BMW v.6.5
* Diagnose v.4.1
* DigiMoto v.4.03
* ECM2001 v.3.2
* Finalist v.1.0
* FordScan v.2.02
* Galleto OBD2
* INPA v.5.0
* KWP2000
* OBD Wiz
* OBDTool v.1.2.60
* OP-Tech2
* Carsoft BMW v.6.5
* Diagnose v.4.1
* DigiMoto v.4.03
* ECM2001 v.3.2
* Finalist v.1.0
* FordScan v.2.02
* Galleto OBD2
* INPA v.5.0
* KWP2000
* OBD Wiz
* OBDTool v.1.2.60
* OP-Tech2
OBDWiz is a good one to get started with. Once you get your feet wet and want to move on, I highly recommend PCMScan or it's successor ScanXL, both from Palmer Performance. I use both a USB Elm 327 interface and a bluetooth Elm 327 depending on what I'm doing or where I'm doing it. It's a bit daunting while learning to use it, but it's capabilities are immense. In some cases it does me a better job than Jag's IDS/SDD.
Good luck!
Good luck!
Cheers,
I wouldn't give up on bluetooth. It works so well if you just use a standard laptop instead of the iPhone or iPad. Mine works flawlessly with a $5 bluetooth dongle or the internal bluetooth in my Dell Inspiron. And it is every bit as fast as the USB hookup. I'm a believer!
Cheers,
Cheers,
No laptop can match that.
I just don't buy laptops anymore. They become obsolete too fast. Frankly, I'm not sure anything works with a WM phone but I think the Ipad probably will work if I switch to WIFI. Apple hasn't implemented the BT for the ELM BT and the Jailbroken stuff doesn't seem to work either. So either a WIFI dongle or USB cable that's Apple "blessed" (god I hate them for this) will be under $100.
Justa thought.
Heck, yes. Almost any old laptop, say with XP, would be fine.
A phone is going to be poor as the display is so small, and then you have the problem that the CPU is not an Intel/AMD x86 compatible so you'll be very short on choices of apps. The ones I saw were really limited, years behind what's available on a laptop.
It does depend, though, on whether you want to tinker for 10 mins or actually achieve something. If the former, maybe don't bother at all. (Because a modern car engine is very complex so the software reports a lot of things and if you don't take the trouble to understand then you just drown in data.)
Staatsof (02-09-2012)
I'm with you on that for the most part, but a cheap laptop kept to use for the car diagnostics would be a good way to go. Obsolescence wouldn't be an issue. You don't by any means need all the newest bells and whistles to do OBDII diagnostics, in fact it probably wouldn't work as well.
Justa thought.
Justa thought.
Cheers,
I have the two shown in the pic. These are Class 1 bluetooth devices, they have a range of two hundred feet or better, line of sight. The one in my Dell is a Class 2 bluetooth, it's range is about 35 feet, still good enough for most things. The big one I've had three or four years, the little one I bought 3 or 4 months ago on eBay for $4.95/free shipping. Hard to beat that!!
Cheers,
Cheers,
At $5 I suppose it's worth yet another gamble ...
Here's a pic of my bluetooth Elm 327 style interface. Most of the time I leave it coiled up like this and let it hang to the floor. I can be anywhere in our shop and the bluetooth connects just fine. Once in a while I uncoil it and drape the interface over the rearview mirror out in the parking lot. I can then read and clear codes or monitor OBDII from my bench. Range just hasn't been a problem for me.
Hope that helps!
Edit: I'll add that I don't consider the ELM interface 'Goofy', it does some serious work for me when I need it.
You know the line, you get what you pay for. Just look close at the version. There is no v1.4a, there is no v1.5 anything. Look for ELM 327 v1.4b.
Good luck!
I bought the very cheapest - looks like the clone Staatsof posted but it's USB not BT. Works fine. I run it far faster (1Mbps) than its default (38400 I think) and it just runs great. Bought a similar-looking one for a mate (absolutely the cheapest I could LOL) and it worked the same as far as I could tell.
Some software called Movi by a company called Hasi works on Apple laptops and requires an Elm327 interface and is suppose to support bluetooth and Wifi. Don't recall if it will also work with an IPAD. There's another Apple App for an iPhone or iPad but I'm not sure how useful it is. The Movi software is about a hundred bucks and they say to download the demo to make sure it works with the Elm327 before downloading the complete version, because they don't give refunds. They also have an Elm327 on their website but it seems to be a few dollars pricier than market.
