P1549 OBD Trouble Code
Hi,
A while back, I received this error and found it to be one of the connectors on one of the IMTs. The wire has pulled from connector and therefore this IMT doesn't work.
Since the wire has pulled out of connector, I would like to know if there is some sort of pre-built kit, a connector with attached wires that I can splice onto wires in car.
Thanks for advice in advance.
I don't know if this will help. Many of the connectors on these Jags are also used on Fords. is a link to a Ford pigtail catalog.
http://www.fordtechservice.dealercon...torcatalog.pdf
Maybe you can find one here that matches yours. Of course, there may be others here that know an easier way to find it. I just wanted to reply before I get to work.
Good luck.
Good luck.
philwarner
25
06-26-2021 05:43 AM
Poet
10-06-2015 09:40 PM
Bob Gelston
09-14-2015 11:08 PM
