Pls help Can't find clunk on front end RESOLVED
I have s type 3.0 v6 2000 I have changed drop links. Had new shocks put on mechanic says the anti roll ok wishbones ok it doing my head in spent 500 quid still getting it . It dosnt do it on speed bumps just pot holes does it on both sides more on passanger chrz please help
benjocabana (10-10-2012)
You need to change the front sway bar mounting bushings. The end links which you changed are only part of the problem.
To prove this unbolt the end links you installed and drive the car over roads where the clunk happens. If no noise change the bushings. Be aware that the dealer will want to sell you a kit including the sway bar itself and the bushings. You can get aftermarket bushings in rubber or Poly if you want something stiffer.
benjocabana (10-11-2012)
benjocabana (10-12-2012)
I don't believe it I thought rite il go n try taking the drop links off see if I can hear this clunk so I started with the worst sounding side I jacked up took drop link off then grabbed arb it got lots play in it didn't need take other side off I was straight on phone to mechanic whent mad told him to get a new mot'st he said hel fit em for free . thanks a lot pal for ur help wel il let u know when he fitted em I gonna go pick bushes up now I hope to god it them
benjocabana (10-13-2012)
MC36
US Lower Atlantic
09-01-2015 07:34 PM
