S-Type 'HOW TO' Guides
Full Jaguar EPC Download, with complete install instructions. (thanks to Jim Lombardi)
Jaguar Acronymns, Abbreviations & Terms (thanks to Don B)
Jaguar Original Equipment Manufacturers (OEM) (thanks to Don B)
Introduction
Hi Everyone,
This is @sjuraud and I'm heading up the S-Type FAQ page. This page has been created to help guide members to pertinent information as quickly and easily as possible. Every effort is being made to be precise with this info. I will consider any appropriate contributions or corrections for entry in the S-Type FAQ (but can only include ones deemed by either me or in conjunction with other Admins and Moderators as needed). This section will be in a state of flux for a while until all the links and kinks get worked out. So please bear with me while the page is worked on.
If there are ANY credits that I missed for links included, please let me know. Also if I gave wrong credit to someone or the author wishes to not be linked to, let me know also.
Thanks and enjoy!
• I'm Buying a Used S-Type; What Should I Look For?
How to Remove and Replace Coolant Reservoir (4.0 MY??, Pre-2003) (tdc)
How to Remove and Replace Coolant Reservoir (aka Coolant Expansion Tank) (v6 3.0 MY03 – ???)
Oil
Filters how_to_fuel_filter_video
Windshield Fluid
Brake Fluid
Steering Fluid
Spark Plugs
Wiper Blades
Color
Body Closures and Sealing
Trim and Linings
Bumpers
Sun / Moonroof reset
Link for Sun/Moonroof spare parts thanks to Abonano
VIN Numbers
Cam Cover Corrosion
https://www.jaguarforums.com/forum/s...3/#post1617385
Oil Pan Removal by joycejag
https://www.jaguarforums.com/forum/s...eaking-141258/ Staatsof
Engine & transmission removal with pics by Tdc (2000 4.0 V8)
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-15/diy-~-s-type-how-pull-out-remove-your-4-0-engine-transmission-faq-64612/
Air and Fuel Delivery Systems
Pre-Facelift Manifold and Plenum Removal Thanks to Daxter
Vacuum Lines About PCM 171&174 Code
Battery / Starter Motor / Alternator
Engine Cooling Systems
Exhaust System and Components
IMT
Hoses
Limp Mode
Management / Emission Systems
Powertrain
Supercharger
Timing chains, Tensioners, Water pump, etc. 2000 4.0 (DIY) replacement
Tune Up
Interior Chrome Lock Cap Removal
https://www.jaguarforums.com/forum/s...ics-faq-66296/
Headliner Removal - Thanks to cabtop
https://www.jaguarforums.com/forum/s...al-how-129199/
Headliner Replacement - Thanks to jya
https://www.jaguarforums.com/forum/s...02-how-221911/
Audio
Information Systems and Controls
How To Add Homelink Transmitter In Your Car
How To Fix Flickering Lights by cstich Nov 2010
Interior Door Panel & Interior Door Handles
Interior Lighting
Occupant Restraints
Parking
Phone
Seating
Security
Steering and Suspension
Vanity Mirror Cover Fix
https://www.jaguarforums.com/forum/s...ics-faq-69401/
Key_fob_facts_all_you_need_to_know
MiscellaneousExtended Warranty
Rear View Mirror Removal by joycejag
https://www.jaguarforums.com/forum/s...ics-faq-57126/
https://www.jaguarforums.com/forum/s...pe-home-58614/ [How To Repair Water Intrusion into the Trunk ] by goblue90
https://www.jaguarforums.com/forum/s...ode-fix-61201/ by eds123
Clock Spring Removal by eds123
https://www.jaguarforums.com/forum/s...val-faq-61287/
Quiescent Current Drain by cat-as-trophy
https://www.jaguarforums.com/forum/s...-drain-123535/
Battery & Battery Charger/Tender
1. Battery 101 for S-Type Jaguars (thanks to Cat_as_trophy)
http://www.mediafire.com/view/hjfrng...ype_Jaguar.pdf
2. PowerTech PRO smart Charger (thanks to Cat_as_trophy)
http://www.mediafire.com/view/3i1943...H_(AUS&NZ).pdf
3. C-Tek Smart Charger in the UK (thanks to Timmyboy)
http://www.mediafire.com/view/anl78s...K_(UK&EUR).pdf
4. Deltran Battery Tenders in USA (thanks to Jumpin' Jag Flash)
http://www.mediafire.com/view/t81uz6...ender_(US).pdf
5. Deltran Battery Tenders in Canada (thanks to Mikey)
http://www.mediafire.com/view/42754o...nder_(CAN).pdf
Braking System
https://www.jaguarforums.com/forum/s...r-x350-103513/
!Special Tip When Changing Rear Brakes:
"... rear brakes on an 03+ with the electric ebrake. Basically that you HOLD the ebrake button/lever down while removing the key from the ignition. Otherwise, you'll end like me, expanding your vocabulary with new combinations of cuss words..." (Thanks Bacardi 151)
Front Hub Assembly
Standard Fitment Guide (pdf)
Electrical
@Gus
How To Change And Replace Spark Plugs by vance
This section below is a compilation of articles and projects completed by one of our members - Gus. He has permitted us to post these directly here, and will link to his personal autorepair web page. Its packed with DIY instructions and pictures. The information is provided by Gus for information and reference use only, and may not apply to your particular situation and circumstances. Please use discretion when using the content.
Introduction
Hi Everyone,
Thanks and enjoy!
- 2.5L V6 (2003 – 2005)
- 3.0L V6
- 4.0L V8 (1999 – 2002)
- 4.2L V8 (2003 – 2008)
- 4.2L V8 Supercharged (2003 – 2008)
- 2.7L V6 Twin-Turbo Diesel
Manuals & Catalogs
(Clicking on the Links Below will Download a pdf or text File)
- Acronym Definitions JagV8
- https://www.jaguarforums.com/forum/g...9/#post1161835
- https://www.jaguarforums.com/forum/g...6/#post1161325
- Downloads (Assorted Tech files)
- Driver's Handbook (pdf)
- Electrical Guide (pdf)
- Parts: S-Type MY 2000 – 2005 (pdf)
- S-Type (MY04) and Options, with prices in English Pounds (£) (pdf)
- Technical Guide @motorcarman
- Telephone Install (pdf)
- Telephone Handbook (pdf)
- USA Vehicle Personalization Accessories Brochure (MY06) (pdf)
- Jaguar Vehicle Specifications (all models - pdf)
- ZF 6 HP-26 Repair Manual (pdf)
- ZF 6 HP-26 Technician's Diagnostic Guide (pdf)
- S_Type_vehicle_maintenance_sheets_petrol_&_diesel
Accessories & Consumables
CoolantHow to Remove and Replace Coolant Reservoir (4.0 MY??, Pre-2003) (tdc)
Oil
Windshield Fluid
Brake Fluid
Steering Fluid
Spark Plugs
Wiper Blades
Crossover Parts from the Ford Lincoln LS
(Please let me know when LS parts have been confirmed to work with the S-Type)
- Upper Intake Gaskets @joycesjag
- Cabin Air Filter: Part # FD02115 @carelm
- Confirmed Crossed Referenced Ford Parts compatible with Jaguars by androulakis
Exterior
Jacking Points Jacking points with pics and diagramColor
Trim and Linings
Bumpers
- Front Bumper Skin Removal (MY05) but may apply to others(w/Pics) @joycesjag
- Rear Bumper Marker Lamp Bulb Change @joycesjag
- Headlight Drooping Repair How To @Brutal
- Droopy Headlights - How To Fix Them To Factory Condition thanks to cubist
- How to Replace Front Bulb by tdc
VIN Numbers
- VIN Decoder @Translator
- Please find below a list of files that will help you to decode your VIN numbers and also help identify your engine, paint, and trim combinations together with control module locations for your car.
Special thanks go to xjrguy for supplying the files.
Daimler Limo.pdf includes Hearse
Series III_en.pdf
X100_en_2000-02_US.pdf XK8 & XKR 2000 MY
X100_en_ROW.pdf XK8 & XKR ROW
X100_en_US.pdf XK8 to 1998 MY
X103_en_US.pdf XK8 & XKR 2003 MY
X150_en_US.pdf New XK range 2007 MY
X200_en_US Part1.pdf S Type
X200_en_US Part2.pdf S Type (shows trim/colour combo’s
X250_en_US.pdf XF
X300_en_US.pdf 1995 to 1997
X308_en_ROW.pdf 1998 to 2000
X308_en_US.pdf 2000 to 2003
X350_en_Final_US.pdf 2003 to 2010
X350_en_US.pdf 2003 to 2006 rough road markets
X351_en_2010 on.pdf XJ 2010 on
X400_en_US.pdf X Type 2001 to 2006
XJ40 a_en_US.pdf 1987 to 1992
XJ40 b_en_US.pdf 1993 to 1994
XJS_en_92 on_US.pdf 1992 to 1996
XJS_en_thru 91_US.pdf to 1992
Jaguar Vin Decoder.pdf Explanations
Some other VIN related tools:
Auto Calculator Site (enter your VIN and decode).
Xclusively Jaguar site (scroll down the page for links to various models) Shown as a chart
Engine & Transmission
ENGINECam Cover Corrosion
IMT
Hoses
Limp Mode
Powertrain
Supercharger
Tune Up
- When Should I get a Tune-Up?
- How To Clean Up TPS and TB by fergs03
- Service Required message reset by Leedsman & xjrguy
TRANSMISSION
- 5 Speed Straight Shift / Manual Shift
- 5R55N Adaption Procedure (MY 00–02) @FactoryJaguarTech
- Want to Drain / Refill your ZF6HP26 Fluid? (@joycesjag)
- ZF Transmission Oil and Sleeve Change @ccc
- Sealed for Life Transmission Fluid Discussion
- Transmission Valve Body Rebuild by tdc
- Oil change kit for 6HP26 6speed Original post by jag79
- 5R55N Fluid Drain And Refill Procedure Thanks to Grant Francis
Diff Rebuild Info & parts list
Interior
Audio
- Audio Schematic and Wiring Info By phd12volt
- DCCV (Dual Climate Control Valve) Source for Parts and Module Repair
- AC Blowing Hot and Cold
- AC has Musty Smell When Turned On
- AC Compressor Replace C/W Pics By Joycesjag
- AC Recharge C/W Pics By Joycesjag
- https://www.jaguarforums.com/forum/s...003-faq-36719/ by justinb67
- Climate control & AC troubleshooting guide Thanks to kr98664
Interior Lighting
Occupant Restraints
Parking
Phone
Seating
Security
- Alarm passive sounder removal thanks to stevep10
- 2005 3.0 Rear Tie Rod and Sway Bar Links Replacement W/PicsBy joycesjag
- S_type_suspension_what_to_look_for
- https://www.jaguarforums.com/forum/s...ics-faq-68198/
Locking / Security Systems / Horns
Key RemoteKey_fob_facts_all_you_need_to_know
- Replacement Key Fob Part # C2C35283 (MY03) @JessN16
- Fob Battery Replacement Vance580
- Open All Windows and Sunroof
Miscellaneous
Wheels & Tires
AlignmentBraking System
Front Hub Assembly
Modifications and Upgrades
Audio- ACM (Audio Connectivity Module)
- Aftermarket Radio
- Chris STR's Alpine System
- Paint
- Engine Replacement
- Mina Gallery Performance Intake
- R-Type Upgrade Discussion
- Upgrading Thermostat Housing
Electrical
- Performance Chip
- Removing Speed Limiter
- Rearview Mirror Navigation
- Removing Navigation Change Limitation While Driving
- Navigation Disc Updates
- Navigation Blank LCD Error 50/51 @jar
JTIS21 CD Download and install thread (thanks to Jim Lombardi)- JTIS (Jaguar Technician Information System) CD @SuperSport
- Headrest DVD
Multimedia Guides & Files
Video Guides- Cabinet Filter Replacement Video Guide @vance580
- Fuel Filter Replacement Video Guide @vance580
- Broken Headlight Fix (vance850)
- Removing the Intake (vance850)
- Changing Oil and Tightening The Nut vance580
- How to Change Transmission Fluid for 6HP26 by Reverand Sam
- How To Change and Replace Spark Plugs by vance580
@Gus
The following 125 users liked this post by sjuraud:
03JagSType3.0 (03-29-2012),
1320racer (02-17-2012),
1FastCat! (10-06-2017),
2005stype (04-23-2018),
2ballcane (04-29-2014),
and 120 others liked this post.
JimC64
40
12-22-2012 03:34 PM
JimC64
05-04-2008 09:58 PM
