Stainless Steel Header for the S Type V-8?
I found some really nicely built stainless steel headers that fit the 2003-2006 Lincoln LS and Ford Thunderbird with the smaller 3.9L V-8. These should fit the S Type V-8. Regular and supercharged. I e-mailed the vendor and they would like to try it out. They are located near Cleveland, OH. Just too far away for me to try it out.
Here is their web site:
http://www.stainlessworks.net/cart/p...oducts_id=1723
Last edited by tbird6; 07-20-2009 at 10:15 AM. Reason: need header changed to correct spelling error. Header not hearder!
That's what's so interesting. The engine compartments and mounting points were identical when the Lincoln LS and the S Type came out. Look at this diagram showing what the cars shared. Everything is there but it would just take something small to make them not fit.
I want to get a set and then if they don't fit the STR I could put them on the wife's LS!!!
Received 2,190 Likes
The engine bays are the same for ls and stype, dimensions of engine are the same, suspensions are for most part the same with some changes to sway bar diam and bushings. I dont see any reason you couldnt put a set of ls designed headers with cats into an stype. I would talk to them and ask if they would be willing to work a deal on a set to check fitment and take pics and notes. Hell the cost is only slightly higher than 1 factory jag u wire cat
The only thing we have to see is if the V8 ( Na ) Lincoln or Jaguar has the same exhaust ports as the V8 Supercharged.
the cats are the small metal cans just down stream(it appears to me) they look identical to the metal matrix hiflo cats I used on my Nissan exhaust build. You can run catless without codes usally with downstream 02 simulators, or by spacing the downstream 02's out of the direct flow of exhaust. there for it would read cleaner than actuall and believe cats are still there cleaning. most commonly used a oil foulers for plug from JC Whitney. you screw them into the 02 port and then the 02 in the back. You have to have room to space them out, but if youre build an exhaust you can change their position to provide room for the sensor. And no i dont meen the Xbrace, and the tranny and wiring looks more like 00-02 Ptec Stype with Ford trans instead of the ZF
Good to know.....but doing long tubes would make the car really loud and not sure if that is what I want when it is already "loud enough"...
http://www.youtube.com/watch?v=XbtINxEVtlQ
