What have I gotten myself into....
Old 05-01-2013, 03:41 PM
Michael Star's Avatar
Default What have I gotten myself into....
Ok well I decided to put on the s/c pulley. Taking it off wasn't too bad, but putting it on is a PITA. So I figured, let's take it out of the car. Will be a great time to replace the coolant hose and maybe track down the vac leak. While I am at it, I will be having the TB bored.
Old 05-02-2013, 08:02 PM
And since I can't leave things looking bland:
Attached Thumbnails What have I gotten myself into....-img_20130502_171541.jpg   What have I gotten myself into....-img_20130502_171626.jpg
Old 05-02-2013, 09:09 PM
clubairth1's Avatar
Received 2,394 Likes on 1,888 Posts
Pretty Cool!!
What did you use? Paint/Powder coat?
Old 05-02-2013, 09:18 PM
I hate to admit it, but it is flat camo green....
Attached Thumbnails What have I gotten myself into....-krylon_spray_fusion_woodland_light_green_flat_camo.jpg
Old 05-03-2013, 06:08 AM
eh... maybe rethink that color... but kudos on going *****-deep into the pulley job, lol!
Did you end up taking off the water cross over in order to cut off the old pulley?
How did cutting off and removing the old pulley go? Did you use a puller once it was cut up, or did it come off easily enough once it was sliced to pieces?
keep up the good work!
Old 05-03-2013, 08:04 AM
Yes, removing it made it tons easier to cut off the old pulley. The problem I ran into was putting the new pulley on. I have a small propane torch and I couldn't get it hot enough to be able to slide it on the shaft.
With the color, I hate to put things back dirty, and I figure with a green car my choices are limited. I think it will look ok (per my mind's eye) but I guess we will see once I gt it all back together!
Old 05-03-2013, 09:45 AM
Also, when I pulled off the TB it looked like this
That seems like a lot of oil circulating through the intake track.
Attached Thumbnails What have I gotten myself into....-img_20130503_093736.jpg
Old 05-03-2013, 11:56 AM
JOsworth's Avatar
Man.... You Jaguar guys need to start running catch cans!
Remember-Modern PCV systems dump into the intake stream instead of into a filter in the air box like they used to (old folks like me remember cleaning that oily filter stuff in our air cleaners).
Most normal drives don't react that bad but those that are driven a little more enthusiastically tend to blow off more pressure therefore end up with a bunch more oil residue.
I'll snap an actual picture of my throttle body the next time I pull the intake tube, but lets just say mine is squeaky clean.
Here is what I use.
Billet Technology Signature Series Catch Can 5.7 or 6.1 Hemi Engines
The neat thing about theirs is that it is all metal, including the filter media.
Very simple to install just need a place to mount the bracket. I'm sure if you talked to Billet Technologies, they could help with the right hose fittings and a bracket.
Oh, and this isn't the first time I posted about this.... LOL
More pictures to get you thinking...
Old 05-03-2013, 12:08 PM
I had to heat up my 3# pulley to get it installed as well. I remember using a micrometer and measuring the outside diameter of the shaft and the inner diameter of the pulley. The shaft was .80" and the pulley was .77" so that is why it is so difficult to press on.
Old 05-03-2013, 12:27 PM
You most definitely have to heat it up, and good. Hot off the heat source, you only have seconds to get it onto the shaft, lined up where it needs to be, and thats it.
Quartz, what did you warm your pulley up with?
Old 05-03-2013, 12:32 PM
Here is what I use.
That might be a very good idea. For a car with 75k miles on it, mine looks horrible.
Old 05-03-2013, 12:42 PM
your meth injection kit will have the added benefit of keeping intake tract clean as well though... catch cans in-line with the pcv system are a good idea too though,
Old 05-03-2013, 12:59 PM
I did start to see where some things were pretty clean with the meth kit, but the amount of oil crude on the butterfly was crazy. The piece from the tb to the aftercoolers was just as bad. I am sure the aftercoolers are horrible too. I am going to try to soak as many parts as I can to clean them.
Acetylene torch.
Old 05-03-2013, 01:53 PM
quartz, just to clarify, you mean like a full on oxy-acetylene torch, or like the yellow acetylene plumbing job torch?
Old 05-03-2013, 02:06 PM
Yikes, I had a small propane deal from walmart....
Old 05-03-2013, 04:40 PM
JOsworth's Avatar
Mine just turned 80k and clean as a whistle.
It would probably help the 3.0 guys as well since their oil pools in the intake manifold and leaks out the IMT valve....
I found out about the Billet piece when I got my 300. It is all over the forum there.. Pictures of the oil they collect and pictures of clean manifolds and throttle bodies..
I was skeptical at first. My car was in the 36k range when I bought it and was already showing some crud on the throttle body. I cleaned it, and added the catch can for the "heck" of it. I empty it out at every oil change. And clean it once a year. My intake looks great ever since..
Old 05-03-2013, 06:09 PM
I sent them an email to see what they recommend as far as part wise. Now I just have to think of where there is room to mount it. I was thinking if I picked up the mina conical filter with heat shield, that would give me more room.
Old 05-03-2013, 11:36 PM
Full on oxy-acetylene. With the two missle-sized tanks on a dolly. Its pretty easy to control the output of it with the right tips.
Old 05-04-2013, 12:40 PM
Received 2,192 Likes on 1,358 Posts
I like the color, reminds me of the inside of F-16's I used to work on. Only alittle more yellowish. Gives it and industrial look
