$3 Sagging headliner repair
OK...It's a repair, not replacement.
I found clear plastic upholstery twist pins at the ACE hardware store
They look like a 3/8" long cork screw with a 3/8" clear plastic cap.
I used 5 strategically placed twist pins to hold the headliner to the foam underlayment where it is coming lose above the back seat.
It has solved the problem, no more sagging headliner, It's not going to win any car shows but it is WAY BETTER and about $497 less than the $500 headliner replacement.
The following 3 users liked this post by maxthrottle:
Received 6,319 Likes
I purchased a Saab many years ago where the previous owner did this.
IMHO, this is an OK temporary method, but as more sections start to droop (and they will) you have to continually to add pins until your entire headliner is covered with chicken pox.
Put the pins in as genlty as possible. If the are twisted in too hard, they can start to dent and/or chip the fiberglass backing. Then, when the time comes for a proper recover, you do not have a smooth surface to deal with. I had a shop do my recovering on that car, and they ended up having to put in a double layer of foam to hide the pock marks.
A headliner replacement is common as our auto ago.
I had a headliner replaced in a 1984 Lincoln Mark VII several years ago.
The total cost parts and labor less than $200. (independent upholstery shop that does repairs for used car lots and individuals is the key) ... to get a good job at a reasonable price. Expect new headliner to last another 20 years.
An independent auto upholstery shop can handle this repair at a fair price.
Remove headliner backing + cleaning old adhesive + spray on new adhesive +
lay new headliner material ----- press/smooth to fit + reinstall headliner.
Your Jag is worth a quality headliner repair ............ Good Luck!
Jumpin' Jag Flash (11-04-2015)
I found a place in Dallas that did a excellent job for $275 on a jag with a sunroof. try www.headliner-magic.com
I've had this on a few Land Rovers and I found that the best/cheapest way to deal with it is using a steam iron (the thing to iron your clothes).
I had to experiment a bit to get the right temperature but eventually I found I could slowly and lightly iron the lining back into place and it lasted for the life of the car.
I believe what it does is to soften the original glue and so stick the lining back in place. Do it lightly or you'll stretch the lining.
It's a bit fiddly because you have to use the iron upside down, but over here we have steam irons where the steam is made in the base - not in the iron - so they work really well.
Once the lining is back in place, leave to cool and then go over the worked area with a soft brush to take out any iron marks.
The following 4 users liked this post by thebiglad:
Datsports (08-22-2015),
Jumpin' Jag Flash (08-22-2015),
someguywithajag (11-04-2015),
Toybreaker (08-20-2015)
The glue has decayed from the heat. Nothing can fix this except replacement of the head liner.
Don't try to re-glue the original fabric because you need to first get all the old glue and foam off the headliner backing. The good thing is it usually just rubs right off because of the heat damage.
It's part of living where it's hot. I see just about all brands of cars suffer from this and it's pretty reasonable to get it replaced at an independent shop.
The dealer will be too expensive.
