"Hazey" Headlamps - A remedy?
ORIGINAL: JimC64
Hey there TBG.........just a thought.
Before you try the wet sand method, which does a fantastic job, but is a ton of work.
Why not try some good ole fashioned elbow grease with T Cut. If it don't work you have nuthin to lose other than a few $ to buy the product?
Just a thought mate![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Jim
Just a thought mate
Jim
Any more info?
TBG
So, I thought I'd try out the process. $15 at Advance Auto Parts and about 30 minutes to an hour of work! Much better lighting at night, and the end result isn't GREAT, but it's MUCH better than before! She's always been a beaut, but now she screams it!
BEFORE
![](https://i169.photobucket.com/albums/u214/bigdreams05/100_1361.jpg)
![](https://i169.photobucket.com/albums/u214/bigdreams05/100_1362.jpg)
DURING
![](https://i169.photobucket.com/albums/u214/bigdreams05/100_1364.jpg)
![](https://i169.photobucket.com/albums/u214/bigdreams05/100_1363.jpg)
AFTER
![](https://i169.photobucket.com/albums/u214/bigdreams05/100_1371.jpg)
![](https://i169.photobucket.com/albums/u214/bigdreams05/100_1370.jpg)
BEFORE
DURING
AFTER
![Name: 100_1372.jpg
Size: 127.1 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/197112d1501341427-%22hazey%22-headlamps-remedy-100_1372.jpg)
Received 9,010 Likes
![Name: cars.jpg
Size: 7.4 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/197102d1501341399-%22hazey%22-headlamps-remedy-cars.jpg)
Brilliant!....Good job Biggie
Now lets see how the other guys get on with the same process?
Some more follow up shots before / during / after from TBG and others would be good too.
I'm thinking as a few members have asked this question I will repost with just the link, lock and FAQ.
Jim
Since I am on a government PC, I cant see the pics but I have the same problem. I already tried one product which did nothing for me. Are they actually "clear" or did they just get better? Personally I would rather just buy new lights(not at $369.00 per side) than to keep purchasing bs. Does anyone know of a solution to make them look brand new or a site I wont have to pay $700+ for a new set? Any help will be appreciated folks!
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Guest
Posts: n/a
hello tallblond guy.i live in clearwater florida,i have been detailing cars for over 20 years.the new plastic style headlights are definitely a burden to cars and the owners.there is a cheap remedy.first of all,it does cost around 80 dollars to fix if you go see a detailer,but beware there is a 3 step process that i gaurantee none of them do.you have to clean the plastic,buff the plastic and then reseal the plastic.sometimes when a detailer waxes a car he goes over the lights with wax and compounds,not good trust me.there are many products out there that fix the problem,pitted lights can be fixed depending on how bad,i have wet sanded and buffed disastrous lights with xcellent results.you can buy the meguairs plastx,but you also need an electric drill that needs to be used with the mothers power ball.i think its 20 dollars for the powerball and 5 dollars for the plastx.anyways make sure you guys tape off the surrounding area so that the only thing you buff is the headlights.wolfgang makes a really great product,i think you can get it from autogeek,or properautocare.com.the wolfgang is the only one i have seen with the cleaner,polish and sealant in one package,it also comes with the attachments for your drill via an orange pad and a black pad.i hope this helps you guys.please do not mess it up,headlights are expensive and i will help anyone out that needs it.feel free to contact me at anytime at ...mlongo2005@yahoo.com.........
#28
ORIGINAL: mlongo2005
hello tallblond guy.i live in clearwater florida,i have been detailing cars for over 20 years.the new plastic style headlights are definitely a burden to cars and the owners.there is a cheap remedy.first of all,it does cost around 80 dollars to fix if you go see a detailer,but beware there is a 3 step process that i gaurantee none of them .<<..........>>..hope this helps you guys.please do not mess it up,headlights are expensive and i will help anyone out that needs it.feel free to contact me at anytime at ...mlongo2005@yahoo.com.........
#30
Badmojo
I'm not too familiar with clear coating the lenses, but my bet is that wouldn't be a good idea. There is a special type coating that they use on headlights to help prevent hazing from happening, and also the yellowing effect that you may not be familiar to anyone here just yet.
I'm from FL too, and I had the same problem on my Lexus SC400. I can give you the full rundown depending on the level of damage to the headlights to make them look brand new. But since I don't have photos of your headlights, I'll just go based off of what everyone else has mentioned.
A proper wet sand, (I recommend a 2-3 part process, of couse using a very fine paper) before using Meguiar's Plastx works wonders. I used it and gave a little TLC to it while rubbing down the lense between each level of sanding. Mine came out looking great!!!!
If you'vr had the love tap courtesy of some old person in Florida like I have, you might also face issues with condensation depending on the weather. In that case, you may have to go with the good old process of resealing with black silicone gel. If that's the case I can give you a more detailed walk through with photos etc. of the process. Hope that helps out.
#31
I bought this product for my Lexus I use to own withdull plastic lights.
http://cgi.ebay.com/ebaymotors/MAZDA...6998QQtcZphoto
It worked pretty good. Basically it has a couple of different rubbing compounds with different ratios.
It does make difference. Check the pic.
Theres another one on ebay
http://cgi.ebay.com/ebaymotors/Dull-...QQcmdZViewItem
Never tried this one.
[IMG]local://upfiles/2319/5B27B3BC9AAF4C48B2705B613C84528B.jpg[/IMG]
#32
#33
Here is someting that I found in an article about sanding headlamp lenses.
After polishing plastic headlights, some CarSpace members have found that the lens often haze over much quicker than they did originally. This is reportedly because the manufacturer coats the lens with a protective layer. Polishing will remove this protective layer. Some of the headlight polishing kits have a final coating you put on after polishing. Or you can use a product like 303 Aerospace Protectant or paste wax. This treatment may help the repair last longer.Hope this helps!
#34
Sorry for the delay,,, I did it,,, bought a kit from a local dude,,, used mydrill as apolisher,,, it's a 3 step process for sanding,,, polish, then clear sealer (to slow the hazing process going forward).
I can't promise I'll include pics, but they look fantastic...of couse, now I'm dealing with other issues regarding my freakin cheap Jaguar headlights (mumbling cuss-words under my breath but I won't post them here so Jim won't kick me off) ...(see other posts)...but at least they look new!
Thanks for all your feedback guys!
#35
#37
http://www.myheadlight.com/index.html
Well I decide to go ahead and purchaseCrystal ViewHeadlight Restorationto see if it will restore my headlights. I will try to go ahead and take before and after pictures. The product was around $20, it was one of the only ones that came with sealant after removing the UV film. It comes with a Lifetime Warranty ans a 30 day Money Back Guarantee.
