00 jaguar s type transmission issue no reverse
Old 08-11-2010 | 07:33 AM
joycesjag's Avatar
Old 08-07-2013 | 11:37 AM
ayeboah's Avatar
Default no reverse, any solution
Originally Posted by 00jaguar
I`m new to this forum and i am in need of some help. I bought a 2000 jaguar s type 3.0L as a non runner. I installed a new engine in it (had a hole in the block from rod failure) and when i went to test drive i noticed i had no reverse. The R lights up on the shifter flour, you can kind of feel it kick in to reverse but it just revs up. if you feather the gas a little bit it will move a tiny bit backwards. i jack the rear end of the car and it will spin in reverse but not under a load. Transmission fluid is full. This car has The 5R55N tranny. Im wondering if it has a bad valve body, band, or solinoid pack. all gears work but reverse. any help would be great.
I am wondering if you were able to resolve the above problem?
Old 08-07-2013 | 11:59 AM
police666's Avatar
Originally Posted by ayeboah
Please were you able to resolve the no reverse problem?
Do you have a similar problem?
Old 08-07-2013 | 12:05 PM
joycesjag's Avatar
ayeboah
welcome to the forum might I ask that you follow forum protocol and properly introduce yourself in the "New Member Area" found here:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
I would also recommend putting your vehicle details, ie. year, model, motor into your signature as well, very easy to do following the directions located in "UserCP"
thebiglad's Avatar
Gear selection problems on this gearbox are often caused by stretched selector cables. Have a look at the set-up on the car and see if there is any play in the cable.
Old 08-07-2013 | 12:33 PM
ayeboah's Avatar
yes
Old 08-07-2013 | 01:14 PM
joycesjag's Avatar
Ok please note this before proceeding on this topic:
Since Ayeboah hasn't stated what year, model and engine we will be chasing our tails on his questions.
Wasting my time I found that he has a 2002 X Type which I believe might just have a total different transmission IDK. Just a heads up.
police666 (08-07-2013)
Old 08-07-2013 | 02:20 PM
ayeboah's Avatar
Default 2002 jaguar x type 3.0L . I installed a used transmission 43k no reverse
I`m new to this forum and i am in need of some help. I bought a 2002 jaguar x type 3.0L . I installed a used transmission 43k and when i went to test drive i noticed i had no reverse. The R lights up on the shifter flour, you can kind of feel it kick in to reverse but it just revs up. if you feather the gas a little bit it will move a tiny bit backwards. i jack the rear end of the car and it will spin in reverse but not under a load. Transmission fluid is full. I'm wondering if it has a bad valve body, band, or solenoid pack. all gears work very well but reverse. any help would be great.
Old 08-07-2013 | 03:08 PM
joycesjag's Avatar
Ayeboah please read post #5 right above.
Also you are in the S Type subdirectory of the Jaguar Forum, please give the guys who are FAMILIAR with your vehicle (in your post in the X Type subdirectory) some time to respond.
Thank you
Old 08-08-2013 | 06:55 AM
police666's Avatar
Mmmmmmm, ayeboah last post is word for word the same as the op post
Old 08-08-2013 | 07:08 AM
jimbov8's Avatar
Is it a case of plagiarism or something else?.
Old 08-08-2013 | 08:12 AM
police666's Avatar
I'm just wondering if he lives under a bridge
Old 08-08-2013 | 09:17 AM
JagV8's Avatar
He needs to be in the right forum.
Old 08-19-2013 | 03:18 PM
ayeboah's Avatar
yes
Old 01-10-2014 | 01:52 PM
ayeboah's Avatar
solve problem.
Reverse gear pin was out
Old 01-10-2014 | 01:58 PM
tbird6's Avatar
What in the heck is a reverse gear pin??
Never heard of it on any car and definitely not on the S Type!
BrentGardner
28
04-26-2024 04:08 AM
stanjag
08-30-2015 11:35 AM
swarm27
08-29-2015 08:37 AM
NorJag
E type ( XK-E )
08-28-2015 08:31 AM
Terrance Williams
08-26-2015 12:50 PM
