01 s-type tranny issue code# p0745..HELP!!
Guest
Posts: n/a
Hey I just found out I have a problem with my tranny. p0745- pressure control solenoid A...
I had just had my spark plugs changed and when they were going in, they said a hose that goes to the radiator had broke on them and they were going to put it back together best they can. After getting my car back, I noticed I did not have any heat. So thefirst thing I did was check the coolant and it was empty. So I added some and I had heat for the next week. I then noticed a week later that it was not coming out hot and when I did have the heat on, my car temp would rise and go to "h" (hot). It would then go back down when I shut the heat off. I again checked the coolant and could see nothing so I added some more. Later that week, I then put the car in drive "d", and it did not go. It took a minute or two and then it jumped forward "caught" and then its fine afterwards. It does it all the time.So the next day I immediately took it back to where I had it fixed and they said that that piece they fixed had broke again and it leaked coolant. But he said that the tranny problem has nothing to do with what they did. If Im not mistaken, doesn't the tranny line run through the radiator to stay cool? If there was no coolant, couldn't that line get real hot and burn up the fluid which would then cause problems..(thickening and blackening of the fluid?)...Please advise....Is it possible that it might be tied in with what happened at the repair shop? What things can cause that to go bad?Any info or advise would be greatly appreciated. Thanks, Justin
Received 2,190 Likes
v6 nor 8? Thermostat? or? turn on your ac the fan should be running for the raditaor, this is a on DEMAND for the fan to check operation. Don't F with coolant leaks, the back cylinders on the engine will get hot with low coolant and air pocketswithout the engine running hot and it can lead to dropped exhaust seats, and no compression. Meaning time to pull the engine apart. And useally a pressure solenoid problem is 2 fold, 1st and cheapest is FLUSH the trans, this may not fix, but sometimes it does if the solenoid is sticking, if not it need a valve body wiring harness in the trans. barring that a valve body fault, but those are the sequence of repairs I would use.
neruda
10-18-2015 01:19 PM
