'02 3L S-Type Intake manifold Insides Coated with Oil/Gears?!?!?!
So I am elbow deep in getting to the coils and plugs on the "Bank One" side of my 3.0L engine. I have pulled off the intake plenum.
The only tough part was getting that 8mm bolt that connects it to the engine in the very back. Whoever was in there previously buggered up that head pretty well. I think I will replace it with an allen headed bot when I put it back together. That will make getting it out easier next time.
But I am really surprised at the amount of oil/grease coating the inside of the lower manifold. I did not flip the plenum yet to see how much is up in there. But there is a really thick black coating on the lower intake.
I was going to pull it anyway so I can replace the PCV valve. I will use some carb cleaner and get it good and clean. (Glad I went ahead and bought those gaskets too.)
Is this expected? I was surprised. Does it tell me anything else that I need to deal with on this engine while I am in there?
I hoe someone who has been into the intake on the 3.0L can tell me something about this.
Thanks in advance.
Greg.
Thanks in advance.
Greg.
Sorry. It has been a long day and I am too tired to type! It is not coated with gears! I hope you read this and have some ideas about how the oil/grease got there and whether it is normal or whether I need to do something to prevent it in the future!
Both banks, 1 and 2 have oil in them BTW. But it looks like there is more in Bank 1...
It's approaching 94K miles.
I took out both of the lower manifolds and used some carb cleaner to wipe the grease out of them.
But I am curious where the oil/grease might be coming from.
I cleaned up the lower 'intake' stage good. It is like new now. Before I put the plenum ('upper intake manifold') back on I will make certain to clean the oil out of it was well.
In a previous post I said I was going to move the fuel injector from cylinder 5 to the other side, but since getting to any of the fuel injectors requires removing the whole rail, I plan to leave them all where they were so if there is still a problem I can see if it comes up in same cylinder.
Thanks again for your help and suggestion.
It was no fun, but the new coils, plugs, PCV valve, gaskets etc. seem to have our '02 3.0L S-type running like a champ again. I have only put about 50 miles on it since I finished her up around midnight last night. But she is starting stronger and running smooth.
The wife (who drives the car and instructs her personal mechanic - me) says it runs like a 'new' car. Phuueeew! I guess I saved a little money not having to buy a new vehicle right now...
Thanks again for all your suggestions.
BTW: Brutal and all other technicians!!!! We need you desperately! Please come back! PLEASE!
The foam is usually where the breather tube connects to the air intake, which is commonly on the side of the air filter box. Those oily fumes are the reason many air fliter boxes have oil in them. I guess those fumes also help coat the MAF and stop it working properly ![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I'm pleased you got it back together and running well. Should be good for a lot more miles.
Bugdoc, I am just getting back to replacing the coils and plugs due to illness with mother. I saw the pics you posted on the drivers side. do you have any pics taking off manifold and anything on the passenger side I might be able to lookat to help in my effort. Aprreciate any direction if on the site where they could be. Thanks.
rusty37
09-18-2015 10:03 AM
RaceDiagnostics
09-13-2015 02:22 AM
jagent
09-12-2015 09:10 AM
