03 S-type..Heat on full blast when AC should be on
I looked at an 03 Stype V8 today. The AC is on and the heat is on full blast. So my guess is the water diverter valve is stuck open allowing hot water to flow continuously through the heater core. The unusual thing is that the heat was stronger on the passenger side than the driver side vents.
Any thoughts?
Any thoughts?
Well I still haven't solved it yet. Air blows cold sometimes and hot sometimes and half and half other times. I have not done a voltage check yet but when i do I will post the results. The dealer wanted roughly 2800.00 to do this "experiment" of changing the valve and module with no guarantee it would work. So glad i did it myself for about 200.00. I don't feel so bad.
Will keep you posted.
Gappa, alittle off topic here but.... If you head over to the "new member section" and introduce yourself, you will be upgraded to full member status. You would then be able to enjoy ALL benefits from this site.
There are quite a few threads with pictures about the DCCV and the CCM.
What part of SC are you located?
thanks joyce, I am in bluffton SC right off Hilton Head Island. I will do that.
this is for a customers car, I usually don't work on Jags but I guess I am up for a challenge. Jaguar seems to do things somewhat differently than other manufacturers. I only do the refrigeration or HVAC in vehicles.
I don't know if you will be able to view pictures yet as a newbie, just google the part number I gave earlier and do an image search.
However the valve does have two cylinders and lives down at the bottom left hand side (from the front of the car) of the radiator, two hoses run up the inside of the wing and the other comes from the main cooling circuit.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 09:11 PM
