03 STR-another replacement parts list
So after repairing the rear suspension from the previous owners accident.I tracked down the fuel delivery problem. Now for round 2
So I have the car up on stands draining the trans fluid because of a pan leak. I get the new pan, fluid and misc parts in a couple days. So I have a few problems to track down while the car is on stands.
-A misc knocking sound in the upper intake-after reading a few threads I looked at the torque converter bolts,1 is missing and 2 are loose. So I need to track down some hardware and perhaps some locktite.
-AC makes a horrible grinding sound when turned on. Looks like the motor mounts are failing which has the motor siting lower on the frame-in turn when the AC clutch engages rubs on the frame-
-Transmount is shot as well- I read somewhere that the Thunderbird or Lincoln may have the same transmount?
ABS DSC issues-looks like I need to remove the module for a solder session-
hopefully that is the fix all-
outer tie rods-shot
shock bushings
engine mounts
trans mount
trans pan & fluid
oil &filter
thats just my observation from 10 mins under the car. Im thinking of getting the Auto Enginuity. If you happen to know a cheap part distributor I need them. I want to do some upgrades but need these necessities finished first. Thanks for reading
outer tie rods-shot
shock bushings
engine mounts
trans mount
trans pan & fluid
oil &filter
Bcrary3
08-31-2015 11:29 AM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
