'03 STR Breath of Life - Help restarting after time
Quartz
Is it relatively easy?
Up on jack stands, and a few bolts and flanges?
At this point, I'm kinda at a loss.
I wonder where a guy would start, if he came to the car with this issue - not knowing the history.
On my list is still
1) Massive air leak of some type
2) Something misconnected/not connected/poorly connected mis-installed
3) Anything that could cause an electrical gremlin - broken wires, corroded contacts
feels like a losing battle
On my list is still
So, as I think on this, I come back to step 28 as well - see the attached.
Is this referring to an actual "ground strap"? What I would typically think of as a wire lead, with ring terminals, bolted down to something?
I don't believe we ever saw anything of such nature when going thru this ordeal. We took the "strap" description to mean the bracket that holds the air intake elbow.....
Anybody familiar with this area or this item?
Clarity here would proally be a good thing, as it feels like I'm chasing ground/electircal issues......
Kind Regards
Kind Regards
Quartz
On my list is still
On my list is still
Clogged OEM cat caused misfires on my 2005 STR. I did not have failure codes for cats but did have multiple misfire codes and specific pluge code misfires. I will find the link and place it here for you shortly...
<Update>
See post #22 and here's the link...https://www.jaguarforums.com/forum/s...g-56188/page2/
<Update>
Sorry to not have gotten back - wanted to wait until I had it completely sorted.
As Joyce indicates main source of drivability issues (all the misfire codes), was an intake leak at the pcv hose, under the TB motor. We capped it, and let the pcv valve vent to atmosphere, and the engine ran reasonably well.
With engine at least running now, I ordered a new PcV valve and hose, and installed those this weekend (3/25).
Again, engine runs well - but now I have a new set of codes to chase.
Thanks all for the help, and ideas were much appreciated.
kind regards,
joe
kind regards,
joe
rachelstr
09-03-2015 12:59 PM
