03 str - hood release broken, wont pop!
Hi guys, tried searching, but doesn't appear to be a very common issue at all.
So yesterday i reach for the hood release in an attempt to pop the hood.
I pull on the release, and it tensions the cable, but won't go any further without breaking it off. I can hear the cable making the sound of 'broken' or 'binding' somewhere inside the fender, half way from the firewall to the hood latch in the front.
I removed driverside front wheel and the inner splash guard to try and locate the cable, but among the wire harness, main battery positive lead, a/c lines, fuel lines, etc, I cannot find the hood release cable at all. It sounds like its deeper inside the fender still...
Has anyone experienced a broken cable or inoperable hood release?
is there a procedure to get access? I'm thinking I now have to reach the hood latch at the front of the hood by going in from the bottom of the bumper.
Downloading the JTIS manual now, hoping I find some info there too.
any input is appreciated,
QuartzStypeR; yes i've tried all those tricks and more to try and open it,
bfsgross; is that the actual recommended procedure? I lifted the car up today and removed all the covers under the front end. Even with a 2 foot long rod going up, i don't see how i can reach the latch... well maybe, but i spied a few other angles from which to reach it.
This is pretty troubling... Not looking forward to actual cable replacement either...
I managed to release the hood today. In the interest of jaguar safety and anti-theft, please PM me for the 'easy' way to release the hood from the outside.
Luckily, cable is not broken, and i've got the release working 100% again. Proceeded to take apart half the front end of the car too...
Thanks guys,
Thanks guys,
Rather than PM people with the details it would be great if you would post a complete answer. You started with a good thread title so someone with the same problem will most likely find it.
Too many people use dumb thread titles like "I hate my car" or "Help me". Those are absolutely worthless as far as helping anybody or even finding the information again.
Received 6,307 Likes
ok ok ok,
Took a 4 foot length of 1/8" stainless filler rod (welding), bent a 90* hook at the end.
Using an LED flashlight, feed the rod through the mesh grill in the front, toward the passenger side hood release, pull on the release to pop.
Then, feed the rod through the mesh grill into the front, toward the driver side hood release, push on this one to pop.
Hood released.
Hood released.
Another solution - just worked on my 2000 S Type tonight - standard grill - passenger side cable broken (snapped off at the junction at the main latch on driver's side)
Release the hood - feed a wire clothes hanger w/ a hook through the grille and hook onto the cable and pull it - the latch will release - what I did was remove the hook on the hood (passenger side) until a replacement latch cable arrives.
What a PITA to even see anything with the grill - took some pics - I will follow up and post them here.
Glad I did remove the lower valiance panel though - I found a nice puddle of trans fluid and a small seeping leak in one of my transmission cooling hoses at the clamp - tightened that bad boy up!
clubairth1
29
05-10-2024 12:57 PM
dude1579
09-17-2015 07:20 PM
