03 str- restricted performance
Did you look the meaning of these up... BIGGEST hint it is the battery is when there are a bunch of codes that don't make sense..IE the car drives just fine yet you have codes related to miss fires / trans issues / and so on..
Is the car running now and do you experience any problems? If no problems I would reset all your codes (now that they are documented) and see what comes up. I would check the battery connections to be sure they are clean and ok. All the Jaguars suffer from a slight to severe case of Poltergeist mostly caused by poor electrical connections. If the car gives you any indication of a problem then you will need to investigate. Until then sit back and enjoy the ride.
