04 XJ8 ZF transmission in an Stype R
Received 2,677 Likes
If memory serves, the drums and clutches are different for the supercharged car. Use the search function.
Here is one such thread:
https://www.jaguarforums.com/forum/s...geable-207610/
dsnyder586 (01-14-2019)
It looks like there are a couple clutches different and perhaps the TC- does anyone have a definitive answer? I *could* tear them both apart to confirm, but was hoping I didn't have to....
If I can swap the TC and then plug it in I would be a happy man. I could have sworn the main boxes were the same for all applications and the valve body or TC and tail were changed for each application?
TCM has to be flashed unless you swap yours into the replacement trans.
You can put a SC ZF6 unit into an N/A car but not the other way around.
If you have a SC engine you need to source a ZF6 with a SC designation on the label.
NBCat (01-16-2019)
audreysue57
16
01-06-2014 03:41 AM
daddycool454
08-02-2013 07:18 AM
msjagowner
34
07-22-2012 06:44 PM
FloridaJag
11-18-2009 11:10 AM
