05 S-type B2736 pedal travel sensor
Hi
My S-type 3.0 has a b2736 code. Pedal travel sensor is what it decodes to. My question is where is it located and is there a way to check it ? Is there a way to adjust it? The car runs great and I have not had any problems, this is why I am thinking it may just be a sensor, out of adjustment or perhaps a bad connection. The light does not come on all the time, it may be off for a week then on for a few days and off again.
Thanks guys or gals being "politically correct"
weltidave (06-13-2022)
Keith - the B2736 code is referring to the gas pedal - at this point it is showing an intermitient code - could be a loose connection. Otherwise, plan on replacing it.
Question, does the gas pedal feel smooth or grainy? If it feels grainy then another indicator to plan on replacing the gas pedal - from what I hear it is an easy item to replace.
Finally, make sure your floor mat isn't curling up underneath the gas pedal - this could be flagging the DTC as well. Good Luck!
05 S-type B2736
Keith, check out the link:
2005 JAGUAR S-TYPE Parts - Jaguar Parts Center - Call (800) 510-1401 for Genuine Jaguar Parts and Accessories
Also Check attached from JTIS - this should point you in the right direction, thanks!
weltidave (09-11-2021)
05 S-Type 3.0 B2736 code problem
I should have mentioned this originally that my traction control light on the cluster comes on at the same time as the amber warning light. I mentioned this and I am told the it has to do with the braking system, but the code b2737 is calling for a pedal travel sensor which is regarding the gas linklage. Now I am confused. My question is where is the pedal sensor located, I was told I have to buy the complete pedal assembly to get the sensor. I have found this on the link you provided and I believe the part is just the sensor. Are they difficult to change? Alldata has nothing regrading this sensor or location. Are there any photo's out there showing the sensor?
Thanks again
KarimPA
09-12-2015 08:15 AM
hen555
09-07-2015 11:13 PM
KarimPA
09-03-2015 07:32 PM
