05 SType 4.2 naturally aspirated , Engine oil leak sudden
I thought I had an oil leak at oil pan bolts by oil filter too. However, first I very carefully degreased entire engine with spray foam (Walmart), rags and long pipe cleaner type brushes (Harbor Freight). (Steam cleaning seemed way too risky with electronics, etc) After cleaning, I found a hairline crack in plastic thermostat housing that was leaking a little coolant down front of engine washing oil residue along with it. So I couldn't be sure if it was coolant or oil. This may not be your problem, but carefully degreasing engine was best few hours I spent. The coolant leak was so small I couldn't even see its source before cleaning engine. I can now see exactly what is going on and catch any problems fast. I got my 2004 4.2 NA at 90,000 miles and someone had apparently replaced leaking valve cover gaskets, but never cleaned up engine. So mine was pretty greasy. But now I love looking at and working on engine since it's so easy to see what's really going on. An additional benefit: no faint burning oil smell from engine anymore. Just a thought....
X_Type_South_Africa
12-09-2015 05:37 PM
