05 Water Leak
05 Water Leak
I have a 05 s type and noticed my rear driver floor is soaking wet with water yesterday. It rained really hard for a few days so I thought it was my sunroof. I cleaned the carpet and started to run the hose on the sunroof to confirm what I thought. Didnt seem to notice any new water. Well tonight I got it my car the floor was wet agian.....it hasnt rained since. So Im back to thinking it my sunroof drain. Must have just leaked down slowly. Anyone know where the drain is located?? Or have an idea of what could be causing the leak. Would this be covered under a ford care extended warranty?? Thanks a lot.....
In an Acura and a Lexus that we had, both vehicles had similar leaks caused by the sunroof drains getting clogged by falling leaf and pine straw debris over the years. The fix in both cases was to locate the very small sunroof drain openings on the roof and blow them out with a compressed air hose. Had to do that a couple of times during the 13 years we owned the Acura. Only had to do it once during the 4 years that we owned the Lexus.
rear floor leak SB#S501-11
Byron...this may solve your problem. SB S501-11 reads, "some s-type
vehicles may experience water leaking into the rear footwells during/after heavy rains. This is caused by water entering the inner door panel section via the door latch. This water is unable to drain away because the secondary door seal traps the water on the inner door aperture sill panel...."
The fix described involves drilling a drain hole. I suspect it might be covered under warranty since in was a design defect. In any event, when you look at the procedure, it's quite simple and perhaps something you could do yourself.
Cliff
Cliff
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
mikimogo
09-22-2015 08:09 PM
mikimogo
09-14-2015 08:34 PM
