06 jaguar s-type v6 84,000 miles in limp mode no check engine lights
I have a 06 jaguar s-type that vent it to limp mode while at a stoplight twice and I turned it off and restarted it and it was fine. The next day I woke up and started the car it went into limp mode and stay in that mode permanently. I replaced the throttle body, accelerator pedal, spark plugs, fuel filter, checked fuel pressure, checked battery voltage, replaced brake light switch, checked for air leaks and it still goes into limp mode. I even have the jlr software and still can't figure it out.
What are the descriptions of those codes according to SDD?
Because they seem unrelated to your problems...
B1262: Climate Control Defrost mode actuator motor drive circuit fault
B1263: Climate Control Panel mode actuator motor drive circuit fault
B1242: Climate Control Fresh / recirculation air flow actuator motor drive circuit fault
Makes alot of sense since these cars don't always throw codes for intermittent bad parts. You see I have no codes for steering angle sensor and clearly something was wrong in that system. Also one of the Vehicle ecm scan said throttle induce limp mode then gave me a bunch of reading I should've taken a picture of it, I can tomorrow. Also my pedal was out of spec but still working, took ohm reading and pedal position readings but it's still wasn't the cause.
Let's go back a few steps.
You said you have the JLR software. Which version? Which interface? (genuine or clone)
On the opening screen with SDD you get any overview of the module communication, and you will see green ticks, question marks or red crosses at each module.
What do you see there?
All your problems sound like electrical faults. Look for water or burnt cables in the wiring harnesses. There is no way all those individual faults just randomly happened all of a sudden. They are all related somehow. You may have blown your computer since it is showing so many electrical related problems.
heroooo
11-06-2015 10:44 PM
NormB
11-03-2015 11:02 AM
