06 S Type 3.0 blew out spark plug
Sonded like a knock while driving, stopped at a mechanic and he felt a coil on plug, making the most noise, front passenger cylinder, No 4? After I removed the coil I found it damaged, the plug was loose,when I went to loosen the plug it was loose, and it was missing the electrode completely. I had a Ford 5.4 Triton engine that blew out plugs 3 times, it's such a common problem you can buy a repair kit that taps a new sleeve and plug in the cylinder, I wonder if one of them would work on the Jag? Or what is the best way to fix it?
Bugga,
We use Helicoils if you can at teh hole, and a 3ltr would be testy at best.
A "nut sert" is another option.
That Ford fix sounds OK also.
Most spark plugs are the same thread, 14mm from memory.
For the electrode to be mashed, it must have hit the piston, so maybe the wrong plug from the go get.
Warspite (03-15-2018)
Received 2,263 Likes
Typical of like generation Ford engines, since there are only 2-3 threads to hold that plug in. Usually the root cause is use of "hotter" plugs, which expand the threads in the head, eventually leading to a spark plug projectile.
On the Ford F-150 forum, the recommended fix is the "sert" job per Grant's post, and OEM plug only (aftermarket, platinum ones are usually the culprit).
Lagonia
02-12-2022 11:18 PM
GvilleVDP
06-06-2013 08:20 AM
benebob
09-15-2010 09:12 AM
