'06 STR Fault code P0128
Had a CEL which showed fault code P0128. I cleared the code and checked the coolant level and it was just below the "Min" mark. I added enough coolant/water 50/50 to raise it between Min/Max. The light has not come back on since.
Would this be what caused the light or is there another possible reason?
Cheers,
fogey0 (04-12-2011)
The ECM knows you start a car, temp goes up at such and such a rate, and should stay up at about 90-95 deg C. If it sees engine temp do something other than that.........sets a code.
Cheers,
knockdhu (10-15-2011)
I recently had this same code (P0128) activate on my '03 4.2L after having a crack in my coolant tank that caused a slow leak. I had the tank replaced and the leak has stopped but the P0128 code has reappeared. I think the leak must have caused damage to the thermostat (or it just died of old age). How difficult is it to replace the thermostat? Thanks.
Thanks, guys. For xjrguy, I read your earlier post and appreciate the good advice. However, the readout I got on P0128 was "coolant temperature sensor", not "coolant thermostat malfunction". That would seem to indicate that the sensor was at fault, not the thermostat. Everyone who has posted on P0128 seems to have seen the "coolant thermostat malfunction:. I can't figure out why my readout was different. Is my (borrowed) reader giving me a false readout? Any insight would be welcome. I'd not like to replace the thermostat and find that the code for "sensor" was still there and then have to try the sensor. Thanks again for any assistance.
Received 2,194 Likes
thanks, guys. For xjrguy, i read your earlier post and appreciate the good advice. However, the readout i got on p0128 was "coolant temperature sensor", not "coolant thermostat malfunction". That would seem to indicate that the sensor was at fault, not the thermostat. Everyone who has posted on p0128 seems to have seen the "coolant thermostat malfunction:. I can't figure out why my readout was different. Is my (borrowed) reader giving me a false readout? Any insight would be welcome. I'd not like to replace the thermostat and find that the code for "sensor" was still there and then have to try the sensor. Thanks again for any assistance.
The dialog for P0128 reads:
Comparison of actual warm up profile with estimated. Judgement performed when actual ECT reaches 80°C or accumulated difference between actual and estimated coolant temperature reaches threshold.
Which means the ECM estimates what the temp should be with respect to what the startup temp was and how long it's been running, etc. Then it compares that with what the sensor measures.
Cheers,
'06 ST normally aspirated Fault code P0128
Excellent info in this thread. My '06 ST VDP had the same EWL and p0128 code (bless Autozone for pulling the code for me). The EWL came on well into a trip and long after the beast was reading normal temp on the dash. The EWL has stayed on for a couple of days.
I presume (suspect) that the thermostat is sticking open or that coolant is bypassing it. I understand that the EWL will clear itself when normal temperature parameters return. I'll be changing out the thermostat. Thanks for the info.
I suspect your engine temp fell during your drive, and the ECM knew it shouldn't do that. If it were the other way, and your temp rose higher than normal, you would probably notice your fans running a little more than they normally do.
Good luck!
EWL out now?!?
EWL is out now, and has been for two days. I now very strongly suspect a sticking thermostat (sticking open intermittently) and will have it changed out, as I'm going out of state the 20th. The last thing I want is to have it stick closed and strand me in the wilds of central Ohio, many miles from help.
Good luck!
clubairth1
29
05-10-2024 12:57 PM
philwarner
25
06-26-2021 05:43 AM
