06 STR O2 Sensor Not Ready
#61
If you disconnect the battery, doesn't that reset fuel trims to zero? Would there be any advantage to doing that, and then see how quickly and in what direction the fuel trims adjust themselves? You might be able to acquire good data more quickly than just driving and letting the trims slowly adjust.
I know this would also clear any monitors, but since they are presently not all setting properly, you're not losing anything.
Still wondering what would happen if you tried a different scan tool, too. Just thinking out loud if it's really an interface problem.
#62
#64
kr98664 (11-26-2020)
#65
After spending almost a year now trying to get this o2 sensor emission ready for smog. I am still at loss. I have called two highly rated Jag mechanic shops and explained the situation. Both are lost and said there's nothing they can do. My last resort is to send the ECU in to get inspected and tested as I can't possibly think of anything else that could be causing that. Who would of thought this would be so hard to get the damn car street legal.
#66
Sorry to hear your still fighting this!
As you posted above have your fuel trims settled down or are they still as high as they were?
Also not much help but where I live you are allowed to have 1 readiness monitor not set and still pass. Have you had them at least try to pass you?
How many monitors are ready and how many or still NOT ready?
#67
I am in California so all the emissions have to be ready sadly. All the monitors are ready except the O2 sensors. Fuel trims are around 5 and 7 which is a little high, but typically go down a little and are not creating any leans codes as they use to a lot a few years ago before I did a lot of vacuum leak services.
I have done multiple drive cycles, resetting the ECU, hard reset by unplugging the battery. I can get all the emissions to pass in literally 20 miles or less. But when it comes to O2 sensors. I got the car up to 700 miles once on a cycle and it was still pending. There has to be something broken. The cats which are usually the hardest to pass will pass in around 10 miles with the drive cycle no problem. But that 02 sensor monitor is still lingering. I called 2 Jag mechanics and offered to pay them to look at it and both said if I bring it in, there is nothing they can do about it. Such a strange problem.
#68
This https://californiainform.com/advices...lifornia-2018/
says you can have one not ready. Is it wrong?
If it is, I'd be tempted to replace any upstream O2 sensor not already changed and hope.
#70
#72
If I'm not mistaking certain sensor readiness will not initiate if there are outstanding issue(s) hence O2 sensors if there is a vacuum leak(s) wacking out the LTFT and STFT's...
#73
#77
Downey (09-22-2022)
#78
phd12volt
06-01-2011 10:28 AM
