06 STR temp gage
06 STR temp gage
sivkov-y - that temp gauge is a real worry. If the gauge isn't faulty then it's a REALLY BIG worry. I would immediately be checking actual temp of various things with a thermometer / IR gun. And via OBD, to figure out where the problem lies. Quite possibly the PCM is getting the fuelling badly wrong because ECT is a critical input to it. (hmm, maybe not else you'd get codes I think.)
If you want to follow up (please do), please start a new thread as it sure doesn't belong in here
Received 6,307 Likes
So I did some messing around with the car today. With the scanner I have under ecm section, I don't see an option for coolant temp in actual degree reading, only a coolant temp sensor voltage reading @ .36v. If I go under the tcm module, there is an option for coolant temperature in degrees but it says -40c. My brother wants to know if there is an up to date sensor voltage chart available for this car so he can run some comparisons. On the fuel trim part, long term fuel trim bank 2 has a variation of up-to 60% when car was started and warming up. When engine is warmed up at normal temp, listening to it, there is a higher pitch sound ether a sucking or an escaping air. tried a can of starting fluid around intake and supercharger with nothing happening, could be a boost leak, don't know how to check this at home. Also my new exhaust, tips are already covered in black sooth, also may indicate car runs to rich. Any ideas, what should I shoot for?
LTFT during warmup is irrelevant.
My 06 str does this too.
turn on the ignition and the guage reads the last temp position it was at when I turned it off from the previous drive. It will then slowly lower to the cold position since, well, the engine is cold, and then it will slowly move as the coolant temp increases.
It has done this since I bought it and seems somewhat normal as well as not a real issue.
Perhaps a guage or sensor issue, but, as of now, not a problem I need correcting.
Having said that, and seeing that this seems to be somewhat of a common occurance, does anyone have a "definitive" answer to why it does this?
I have no answers either, mine does it also, and to me it's no big deal. That's life..
I just came home from work, kept an eye on the temp guage, when car is started and cold, temp showed normal operating temp on guage. After about 30 sec of car idling, temp guage falls to cold position. Any ideas, is this not supposed to be, its been like this ever since i got this car?
Well its been a while since I took on the temp gauge issue again. I just replaced my temp sensor today need to see if this has any thing to do with my cats going bad in less than two years (Magnaflow hi flow spun cats) I thinks I may have a faulty fuel/air ration mixture. Also I am planning to replace my Magnaflow cats with some Vibrant performance true hi flow cats.
