07 Purge Valve
07 Purge Valve
Can anyone help with a part number or source for this purge valve? On my 2007 S-Type Base 3.0, it is located at the front, right behind the radiator, and the design is different from the models that have the resonator assembly attached to the firewall. I cannot find this part listed anywhere. It is a Denso part, but I can't make out any part numbers.I don't think I can get the other type of valve to fit, as it has a different fitting for mounting, and the pipes are both on the same side, whereas mine they are on opposing sides.
Oldengineer
04-11-2009 03:48 PM
