1999 Stype 3.0lt
1999 Stype 3.0lt
Salutations,
My 1999 S type recently disgraced itself by having to be brought home on an RAC low loader. Cruising at 60mph the engine suddenly died and i managed to coast off to a safe area. The RAC was summoned as it would not start even though it was turning over freely. 3 days after it was safely returned home an RAC patrol came out to give me a diagnosis but the ******* started first time! So no diagnosis. I had a similar problem with my recently deceased XJ40 and it turned out to be a dodgy crankshaft sensor which would fail when hot but work fine once cooled down. Is this a similar common fault with the S type? I originally suspected a failing fuel pump but I have found with past experience that these electric pumps just die and cannot be resuscitated. Any suggestions?
I have an el cheapo OBDII but it shows no codes. My son in law has a better reader for his S type diesel and i will borrow that. I did start it again today and it fired up but smoked a bit which it has never done before so it could be dodgy supermarket petrol. As soon as i get the codes i will post them but thanks for the help.
S-Type Owner (03-06-2024)
Warren Lieuallen
19
06-10-2023 10:12 AM
Doug
08-14-2013 02:04 AM
Mack
01-02-2012 09:50 AM
