2000 Jaguar S-Type 3.0 No Heat
I have a 2000 Jaguar S-Type 3.0 with 81,000 miles. Nice car, runs great. I've had it for 3 years. But I have NO heat right now, and the temps are getting very cold.
I brought it to my mechanic, and he can't figure it out. He's baffled. First thing he did was he flushed the heater core. That did nothing. Then he changed the thermostat, again, nothing. Then he replaced several hoses. Nothing. Then he bled the system, because he thought there was too much air in the cooling system. Again, nothing. He's already put 2 days worth of work into it, and have spent $200 in parts.
This is very aggravating, because I still have NO heat. I see that this is a very common problem amongst S-Types, especially 2000's.
Any suggestions, tips, or anything would be VERY helpful. I drive to work every morning with 35 degree temperatures, freezing the entire time, and it's only going to get worse. I never thought in a million years my mechanic couldn't figure it out. I've been taking my cars to him for 15 years.
That's the problem. The things that most people have done, my mechanic has already done, and it didn't work. Basically, right now, he's recommending replacing virtually everything that it COULD be, because he can't figure it out. He could end up replacing $100's of dollars worth of parts that are fine, which I don't want to do. This has already cost me $400 and I don't have a single drop of heat. If he goes step by step replacing parts, it could be a $1,000 job.
I don't understand why the 2 responses I've gotten to this thread have been arrogant. I'm looking for some help, not arrogant responses. If I want arrogance, I can walk into the Jaguar dealership.
Read the many posts concerning the dual climate control valve (DCCV) and the climate control module (CCM). The DCCV usually fails, and if it is not caught and replaced in time, it can short out the CCM. Your vehicle is probably suffering from one or both of those failures. So take the time to do the reading, then speak with your mechanic about it. Your posts thus far do not indicate that either you or he is aware of this. That's not arrogance, we're simply trying to help you help yourself....
Am I arrogant or are you LAZY?? That's the real question. Get off your fat butt and search this forum for the most common problem that has been talked to death and ALL the part numbers and source of parts explained.
But instead you want to whine. Boy that will fix it alright.
Very much the problem with US. You must have GREAT self-esteem though!!
Received 6,361 Likes
Keep calm guys, it's frustrating for the regulars to see the same questions asked time and again when they know the answer is only a search away, but maybe the new guy has been under his car for a few hours and is frustrated too and is just looking for some help.
Either way let's not start name calling and bad mouthing other members.
@Jon89 You gave a very good reply. Perhaps his searches reveal may answers and didn't point him to read about the DCCV. And by telling him to read about it is a very good suggestion.
@Jag V8 You do a very good job helping others but sometimes your answers to problem seem very vague.
no heat
and the very first one for the S-Type was essentially his problem (no heat) cured by changing the DCCV (which was named as the DCCV).
The 2nd about the S-Type also refers to changing the valve to get heat.
How much more help does anyone need?
'00 stype 3.0 no heat
I've added coolant and the tubes did get hot and there was a little heat but not much. I did notice a leak under the overflow tank which will have to be tended to but after the problem is solved. Any suggestions, it's getting cold out and the heated seats aren't enough.
IvysMommy (12-21-2020)
Try looking at this site DIY: Diagnose It Yourself - JaguarClimateControl.com it shows the DCCV, and other useful stuff that may help, if you carefully unplug the Dccv cables you should get heat as it should default to open if you still do not get heat then this may point to the valve being faulty
no heat in 2000 stype 3.0
Over time and various posts you get to know the people responding and direction with their responses. Like this original poster, in the beginning I would get upset when I would post and the response would be search for it. I would think "What the heck was that response, why don't you tell me where it is and then I don't have to search for it"....but then realized after a little while......"Oh I get it, the site is free and maybe I should do a little work for the reward".
I have learned that if Jagv8 just responds with a do a search, I then know it is somewhere on the site and at least know if I search I will find it. Would not tell me to search if it wasn't here.
Er, thanks - I think!
On any model, unplugging the DCCV electrical connector will make the DCCV go open - but only as far as your car's DCCV is able to go. If it's damaged it may hardly open or may be stuck open or anywhere in between. And the D means that applies to each half.
Sorry not always to be as helpful as people would like but I kinda hope you'll learn how stuff works and how to fix it. Like that stuff about teaching someone how to fish rather than just handing across a fish. DIY rather than get me to do it for you (not that I can).
You can be sometimes very straight about responses but as Norri said answering the same question a zillion times can get trying. Look at it as you are a good teacher encouraging your students to seek for themselves and they shall find.
The fish analogy sucked though. If fixing this freakin car was as easy as learning how to fish, I would be a fishing god.
