2000 Jaguar S-Type 3.0 power window
Hello> I have a 2000 Jaguar S-Type 3.0 My power window all work at the drivers door pandel but all the other doors pandel won't work. I'm thinking the child safty botton is not working. I thought I ask for some help before I rip into it. Thanks so much!!!! Sorry for the bad spelling lol
Hartleys (03-14-2012)
Hartleys (07-27-2013)
FIX FOR THIS ISSUE :
I had the same problem with my 2000 S type
all Windows went up and down from the drivers panel but all the other window switches didnt work.
Replaced the drivers switch thinking the child lock button is faulty and the windows switches on the passenger and rear doors still didn't work
I got my voltmeter out and found that the child look switch was working.- voltage going to the drivers door module
I then checked the rear module in the boot and the the positive power output that comes out and goes to all the switches was dead
( pin number : CA102.5 ( yellow wire )) i guessing a module fault
I hot wired this wire directly to the battery and all the windows switches work now.
Tomorrow im going join the Yellow wire to CA1013-13 ( Orange black wire ) ( no1 fuse in the rear ) switched power input for the rear module ( used for the boot lock and also for the windows )
all the window motors have there own fused power supply so there shouldn't be any worry about current draw.
Hope this helps someone in the future
Oh, it sounds great
My car is just at the mechanic's garage with another issue and I'll ask them to look at it.
Where exactly can they find this rear module? Or do they need to do this operation that you described below at the rear module or at the fuse box:
"Im going join the Yellow wire to CA1013-13 ( Orange black wire ) ( no1 fuse in the rear ) switched power input for the rear module ( used for the boot lock and also for the windows )"
mhamilton
09-23-2013 09:19 PM
A238
04-13-2013 09:33 AM
nickthap
23
06-09-2012 07:31 PM
EZrider800
47
05-16-2011 01:14 PM
