2000 Jaguar S-Type 4.0 Overheating
The temperature gauge shows overheating on the freeway when going over 70 MPH. When I slow down and turn on the heater it cools back down. Replaced the temperature sensor. Still doing it. Not using any coolant. When I pull over and turn the engine off and check the fan is running, radiator feels cool. The upper hose is hot but the lower one is much cooler. Could it be the thermostat if the heater is working?
In my opinion it sounds like a coolant flow issue?
First two things to check.
1. blockage in the radiator
2. water pump flow rate.
From reading some past threads on here..your engine was prone to water pump impeller fins failing.
How many miles are on the vehicle and have you ever flushed the coolant?
It could be if the heater feed is from head side of the engine as I would expect to make sure heating starts early. It is not an expensive thing to swap out. Is the engine/engine bay area hotter than expected?
Received 2,652 Likes
...When I slow down and turn on the heater it cools back down. Replaced the temperature sensor. Still doing it. Not using any coolant. When I pull over and turn the engine off and check the fan is running, radiator feels cool. The upper hose is hot but the lower one is much cooler. Could it be the thermostat if the heater is working?
Do not rely on the instrument cluster temperature gauge to determine the coolant temperature. Use a smart phone with an app such as Torque and a Bluetooth interface connected to the vehicle's OBD port to read the current coolant temperature.
nocode3rdeye
03-15-2015 09:51 AM
chrisc923
03-15-2012 08:47 AM
