2000 jaguar s type no start
hello gents, I have a 2000 s type 4.0 with 100k miles in good shape, its been parked up for several months and now it wont start, it cranks but does not turn over, before being parked, it started fine. it has spark and fuel pressure, not sure what else it can be..i would love to get some help from you guys.
thanks
thanks
![Icon Steer](https://www.jaguarforums.com/forum/images/smilies/icon_steer.gif)
Gus has written a great troubleshooting guide:
JagRepair.com - Jaguar Repair Information Resource
Scroll down near the bottom to the links describing cylinder wash problems with Nikasil engines blocks.
First put the accelerator to the floor and then crank it over as it may have flooded.
if that dont work put a little oil -half a tablespoon down each sprk plug hole and then try it as normal.
The v8 engines flood easily if they dont start quickly and do suffer from borewash.
make sure battery is fully charged.
Good luck and report back
thanks
thanks
Fuel pressure under 42 psi at any point is a problem for the 4.0 engine, including prior to engine start.
The early S Types are notorious for failed pumps (seized) after sitting for prolonged periods of time.
You should also hear a pronounced 2 - 3 second "woosh" sound when turning the ignition to run before cranking. If you don't hear it or it's garbled, your pump is toast.
Good luck
I would borrow a fuel pressure gauge from the big box auto shops that lend tools and follow steps provided in my previous post to determine fuel pressure and rule it out.
romeo8426 (02-23-2016)
Yes, that is where you want to check your fuel pressure. Most fuel pressure tester adapters should work, including Ford.
tat2ist
27
05-20-2022 09:41 AM
Jennifer S Flavell
03-18-2016 07:42 AM
kulddy
12-31-2015 12:25 AM
Luis Rodriguez Lum
12-21-2015 02:06 PM
