2000 Jaguar Stype 4.0
I've got a 2000 Jaguar Stype 4.0 with 80k.i bought it wrecked replaced the entire front end bumper hood headlight grill etc.. Spent almost three grand. Car has set three years and now that I'm driving it I have a miss. I replaced the plugs and one bad coil pack and still have a miss. I noticed the oil cap is white and milky on the bottom also steams while running from the egr and oil fill. I haven't had to add fluid and it's not over heating. What could the issue be? I'm thinking head gasket
How did you determine which coil pack was bad? You may have more than 1 bad or failing coil pack. Good Luck!
When I changed the plugs they were clean and dry. Coil packs were the same. I found by unplugging each coil pack individually only one wasn't making a difference when plugged or unplugged. After installing all new plugs the car ran even worse. I put the old plugs in and it ran perfect. I just have a miss or stumble every now and then. I also found if I don't run water remover (heet) the car runs awful. I've never had to add coolant and have removed the egr tube to stop the oil and steam from going in the throttle body . I don't see the milky oil on the dipstick just on the oil cap and egr port coming from the valve cover and the engine never runs hot. I'm guessing your talking about the Valve Tensioner? Would those cause the oil blow bye and steam?
Received 9,011 Likes
water getting in
Open the hood and run water from a hose up near the top on your windshield. If any water is going under the seal at the bottom you'll need to seal it with a black sealant.Water can get in the engine bay and seep under the coil/plug seals and cause a misfire. I have had the same year and engine with lots of misfire problems until I sealed up the coil and windshield areas.
