2000 S-type 3.0 transmission slipping
Guest
Posts: n/a
Has anyone experienced the same? My 2000 s-type 3.0 tends to slip and the engine races intermittently. Had transmission drained and refilled once but still have the problem. Took it back to check level and color of fluid. That is OK. Over time I have noticed two interesting things regarding the occurences. First it seems to operate OK when it is cold, and worse when it is warm. For this reason I suspected something related to the viscosity of the fluid or perhaps an internal transmission pump or controller that weakens as the temperature rises. But then, I also noticed if I pull down on the shifter when it occurs, it seems to help. I did have the shift cable replaced beacause it had broken after parking on an incline. Since then, I have had some close calls getting the transmission stuck in park on an incline. This leads me to wonder if the cable might have stretched ever so slightly, and lengthens even more in warm weather. Could the indexing be off on the selector, and would this cause the slipping and racing of the engine previously mentioned?
Your experiences and expertise are greatly anticipated and appreciated!
mtfife
mtfife
Guest
Posts: n/a
RE: 2000 S-type 3.0 transmission slipping
I have been reading about Jaguar technical service bulletins regarding a pcm (powertrain control module) or tcm (transmission control module) reflash. Is this a possible soultion for my symptoms, and if so is anyone familiar with the range of charges for this reprogramming?
aholbro1
08-05-2021 05:02 AM
