2000 s type 4.0 throttle body tps or pedal problem driving me nuts :)
I have a 2000 stype I picked up about 6 months ago , i drove it from nj to fl and on the way back to nj the car started acting up , in nc it began.
Fail safe engine more went into limp mode continuously as we tried to drive closer to our Aaa towing range allowed . We got to pa and had it towed home .
I did slight research and read that it could be possible tps problems so I cleabed the tb and cleared the codes and it drove fine for a while till it did again .:
Now what I have noticed is in cruise control set at a speed the car drives flawlessly , as soon as I need to use the pedal it begins limp mode immediately .
I pulled and reconnected the plugs on the pedal tps and iac I beleive (big unit on front side of tb) after reconnecting them it drove ok till now but it's only been a few miles.
I know th problem will return and I'd like to fix it because I love it the car and don't want to sell but it's beocming frustrating especially driving with my children .
The codes I'm getting are p1576,p1573,p0065...
Can someone please help me or get me in the right direction ...
I
Have done many searches on the forum but haven't found any direct threads maybe I'm
Not searching correctly
..does anybody beleive it pedal related or strictly tps...
I
Sorry forgot to mention I thought battery might've been related so I put in a brand new one last week.
Also where is the pcm on this car located and where is the rear electronic module located as well..
I need to check if moisture is getting to any of them .
I have called the dealer and asked about
A new tps sensor witch will cost me $289 through jag
A new pedal assembly witch will cost me $234 through jag
And about an hour of labor to program the components witch they told me must be done $130
