2000 s type(93k)Engine fail safe mode
Old 06-25-2008 | 02:17 PM
mrhayat's Avatar
Default 2000 s type(93k)Engine fail safe mode
Hi,
FJT can you pls advise on this. The last thing I did was got the coil changed as there was a cyl misfire code. I asked my mechanic to clean the throttle body also with some cleaner fluid sprayed on a rag. Now I get this Engine fail safe mode sign after 2 weeks. I havent got the codes pulled yet. But any clues what I could be from past experiences?.
Old 06-26-2008 | 08:09 PM
FactoryJaguarTech's Avatar
Default RE: 2000 s type(93k)Engine fail safe mode
Failsafe on stype is normally caused by throttle problem. Could be tps fault or PCM.
Need the codes as always to be of anyhelp.
MJ'S Jag
11-10-2022 09:14 AM
Fraser Mitchell
10-01-2015 05:06 AM
stanjag
08-30-2015 11:35 AM
nelsonht
08-30-2015 07:01 AM
peterg19
08-28-2015 09:42 AM
