2000 S Type Backup Camera Installation
Guest
Posts: n/a
I have a problem in identyfing the wiring into the rear light fixture, in order to connect the backup camera to work only when reverse is selected.
There seven wires:
2 Black/ yellow
2 Orange/ red
1 Green/ black
1 Black/ orange
1 Black/white
Can anyone help?
There seven wires:
2 Black/ yellow
2 Orange/ red
1 Green/ black
1 Black/ orange
1 Black/white
Can anyone help?
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/706x454/screenshot_20180830_230835_2_455299367d6a3428d20d95f623e96105bdf68f54.png)
LH tail light wiring from electric control module
Wiring Color Codes
N Brown
O Orange
B Black
S Slate
W White
L Light
K Pink
U Blue
G Green
P Purple
R Red
Y Yellow
BRD Braid
The seven wires:
3 Black/ yellow = Tail, Fog and Turn grounds
2 Orange/ yellow= Tail/Stop and Reverse/Fog/Turn 12V power
1 Green/ black = Reverse ground (pin 4)
1 Black/ orange = Stop ground
LH reverse light wire is BG (black/green)
RH reverse light wire is BR (black/red)
Parking aid gets juice from WR (white/red) that's connected to the Left Hand side reverse light ground wire BG. This is where I would put the connection.
If you don't need to connect directly to the light connector, consider (LH) Parking aid unit (pin 9) and (RH) Rear electronic control module for connecting. Peel the harness trunk side where you want the connection, if spare tire well is not a good place. Check also Rear electronic control module 17-way connector (ca63) pin 9. You might find both BG and WR wires there since the wiring don't actually change, the schematics do, along accessories.
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/557x267/screenshot_20180831_002546_2_d97ac1dc967382f9e3d995990e949082a2c9a235.png)
Rear electronic control module pin arrangement
stanjag
08-30-2015 10:35 AM
02, 2000, back, backup, camera, install, installation, installing, jag, jaguar, navigation, reverse, stype, type, wiring
